1 - 17 of 17 Posts
How many of you folks in the colder climates have issues shifting when the trans is at ambient temperature, i.e. below freezing. Mine just doesn't want to move first thing in the morning, just like its driver. Temps have been between 20* and 30* F and shifting from 1-2 and 2-3 requires a good shove. Once its up to temp, the shifts are very smooth.
--Matt
In the cold, down to 2 is difficult....down to 1 is very difficult, even at a complete stop sometimes. But to be honest, its not too much different from other vehicles I've had.
Mine is a bit stiff on cold mornings, but so is my other manual car.
Mine is a little cranky in the morning cold. But no different then any other MT's I have owned.
Just requires a little patience.
the only MT's that worked like butter down to zero degrees all ran atf in them.
my jeep has light gear lube, my old ranger with a 5 spd mazda trans had atf juice.
what do these nissans run? sounds like gear oil-which is good, you just have to get it down the road a mile or two to get some drivetrain temp.
My AT shifted pretty abruptly the past two days. It's been -5 or better here in WI.
I have found that my clutch likes to squeak when it is cold. Has anybody else noticed this? As far as shifting, mine is a bit difficult, but nothing compared to my '90 Subaru Legacy.
Mine won't go into 2nd unless i'm almost stopped. So I have to lug 3rd in the morning. Even after i've warmed it up for a few.
Mine has been annoying in the cold. 1st to 2nd is a real PITA.
Sucks because I only drive a mile to work so it never warms up.
1 - 17 of 17 Posts
