1 - 20 of 209 Posts
Username: 5l33p3r
Year: 2009
Trim: X (2wd, 6 Speed, M226 w/3.54's)
Color: Night Armor
New Build List 11-2-13
Front Suspension:
SPC Xterra Upper Control Arms
Moog Xterra Lower Control Arms w/ Prg Delrin Inserts
Moog Xterra Tie Rods (in & out)
PRG Extended Stainless Brake Lines
PRG Camber Bolts
OEM Spindles
OME 607 Coils & Shocks
1" Aluminum Spacer
Rear Suspension:
OME Dakar Leaf Springs & Poly Bushings
PRG Adjustable Shackles
OME Shocks
Armor/Exterior:
Krawltex Front Bumper & Aluminum Bash Plate
maXTERRA Rear Bumper
NXRocks Radiator Skid
NXRocks Engine Skid
KrawlTex 1/4" Aluminum Transmission Skid
Synergy "JK" Hood Louver Panel - waiting to install
OEM Xterra OR Gas Tank Skid
Monstaliner (on all of the above)
Lighting/Electrical:
Hella Rallye 4000 Euro Beam (Pair)
Rigid Dually Amber Floods (Pair)
Totorn 12" Combo Beam
Optima "Yellow Top"
Powertrain / Drivetrain:
Doug Thorley Longtube Headers
Doug Thorley B-Pipes
Doug Thorley Cat-Back w/ Spintech Muffler
Nismo / AEM Hybrid Intake
K&N 5/8" Valve Cover Breather Filter
XTP IMS
Stillen Grounding Kit
UpRev Osiris Software & Custom Tune
Wheels & Tires:
SpiderTrax Adapters (Front and Rear)
17x7.5" Titan OR Alloy Wheels
285/70-17 Goodyear Wrangler SilentArmor Tires
OLD BUILD LIST 4/10/12:
Front Suspension:
PRG Titan LCA's (OregonX)
Plated/Reinforced OEM Titan LCA's (OregonX) w/ PRG Delrin Bushing Inserts & Moog Ball Joints
PRG Heim End Titan Length Tie Rods (OregonX)
PRG Camber Bolts
CST Frontier/Xterra Lift Spindles
~~COILOVERS: TBD~~
Rear Suspension:
OME Dakar Leaf Packs w/ OME Poly Bushings & PRG AAL's
Custom Delrin Frame Bushings
~~REAR SHOCKS: TBD~~
Armor/Exterior:
NXRocks Engine Skid
OEM Roof Rack Deleted
~~SLIDERS & FRONT BUMPER: TBD~~
Custom Magnaflow Cat-Back Exhaust
XTP IMS
Wheels & Tires:
OLDER BUILD LIST:
Front Suspension:
Total Chaos Titan UCAs
OEM Titan Spindles (w/ “Small” Titan Brakes)
OEM Titan LCAs
ICON 2.5” Coilovers (w/ Custom PRG Spacer)
PRG Tie-Rod Extensions
PRG Camber Bolts
DayStar EVS 1 3/8" Bumpstops
Rear Suspension:
OEM 2WD Leaf Springs
PRG/Deaver 2 Leaf AAL Pack
Fox 2.0" Remote Resivoir 10" Travel Shocks
DayStar EVS Shaft Mounted Bumpstops
OEM Frame Mounted Bumpstops (2" Spacer Installed)
Wheeladapters.com 6x4.5 to 6x5.5 Adapters
RockyMtnX / import silvia inspired front bumper w/ custom tube work done by Krawltex
NXRocks Engine Skid
Custom Aluminum Transmission Skid
Xoskel Lightcage
Hella Rallye 4000 Euro Beams (Front Bumper)
Hella 500's Driving Beams (Front Bumper)
Hella SuperTone Horns
VDC Relocated
Doug Thorley Cat-Back Exhaust
Wheels & Tires:
17x7.5 Titan OR Wheels
285/70-17 TreadWright Wardens
17x7.5 Titan XE Steel Wheel (spare)
285/70-17 TreadWright Warden (spare)
Comments:
6/1/11 - SOLD my TS Parts & alot of the exterior stuff... I wasn't getting the performance that i was wanting, it was always lacking just a bit... so i bit the bullet and reverted back to semi-stock until i'm able to do my full on build and turn this into a dedicated toy/chase rig... stay tuned...
Stock:
OR full suspension:
OR suspension, 265/75-16 Treadwrights on stealther X wheels:
original stealthed 09+
Hella 500FF behind grille
OR suspension with 265's vs. stock 2wd
TS parts:
TS 2wd:
Dyno sessions @ UpRev:
baseline -
final tune -
stickers
NXRocks Skids
Stealthed Wheels
"ROOK"ed Titan wheels
285/70-17 Wardens Mounted
Front Bumper
Xoskel Lightcage:
CST Lift Spindles/OR Bilstiens (Front & Rear)/2WD Coils/2wd Leaf Packs/PRG AAL & Shackles:
Finally figured out and finalized the rear suspension this weekend guys... Spent Saturday at krawltex in Austin, we'll be starting the cantilever set up in April!
And thank for the replys guys, glad y'all like it more pictures from this weekend to come...
great looking X there Travis. really sharp! loving the TS...u better not get rid of it! :) also where did you get your rear extended bumpstops? i need to get extended ones because of how much travel I have and how long the shock is.
Rook, heres the link to my rer bumps... they'll be installed once i get the rear suspension redone.
http://www.polyperformance.com/shop/Bilstein-Air-Bump-Stop-p-19270.html
at the moment i'm running these:
http://www.polyperformance.com/shop...Bump-Stop-with-Slotted-Mount-Plate-p-208.html
but these might do well for you:
http://www.polyperformance.com/shop/Daystar-Stinger-Bump-Stops-p-26466.html
-t
*droooool*
great job w/ the truck so far.
questino for you, I am REALLY close to pulling the trigger on some 17" offroad wheels. I have a good place for 1.25" adapters for them.
What size tire are you going to be running on yours? I know it's a bit different since you are t-swapped already. I was thinking about 285/70/17's but I am unsure how much trimming is going to be needed w/ the wheel spacers/adapters.
Discussion Starter · #10 ·
*droooool*
i'll be running 285/70-17. how much lift are you running? you shouldn't have an issue with 1.25" adapters and 285/70-17!!!
-travis
I've got AC's 2" lift coils on stock offroad Bil's up front. I *think* i'll be ok. I would really not like to have to cut anything.
Discussion Starter · #12 ·
you shouldn't have to cut anything, but the melt mod will be required... with the stock 17" ORs and 285s with adapters you should have a stance simular to the guys running procomps and 285s... and if there is any trimming it will be very minimal on the rear most portion of the front fenders and the fender liner will cover it. Rook has done a good bit of trimming and he might be a good source for how to trim the fenders if needed.
the only way to know for sure is a test fit... i do know that 255/75-17s will fit with out the need to trim anything... they are a bit taller than 265/75-16s but a bit narrower...
i'll keep ya posted.
-t
sounds good! that's what I was thinking, but i wanted to make sure. how about another ? for you. are the TPMS off of the xterra S/offroad/SE wheels the same as the tpms on this type of titan wheel? i know there is a diff between the steelies and alloys.
the news just keeps getting better and better! sorry about the thread hijack. when are you putting the red's on?
Discussion Starter · #16 ·
waiting on spindles to get here, then i need to get to krawltex to fab up the rear shock hoops... after that i should be 99% finished... i'm hoping i'll have everything finished and ready for final paint/spray liner by mid march...
Discussion Starter · #20 ·
FedEx dropped off the tires yesterday, got the tires mounted today... just waiting on my stainless lines to get here so i can finish the front Titan break swap.
-travis
first post updated with tire pictures!
1 - 20 of 209 Posts
