Well since we have a lot of new people to the whole off roading experience and some of us are still rather new to it I thought that this would be a great way to introduce them to our little world. I've included some of the many things that I have learned along the way. IF you have any please feel free to add them to this topic. These are just a few of the ones that I have learned along the way. I'll post some more later on.
Before you go check the following.
Engine oil
Tansmission fluid
Brake fluid
Hydraulic-clutch fluid
T-case oil
Diff oil
Power steering fluid
Belts
Grease all driveshafts, U-joints and steering joints.
All lights and turn signals.
Winshield washer fluid
Radiator fluid level
Tire pressure and look for leaks or gashes
Tow hooks front and rear
Tell someone where you are going and when you'll be back.
Check for loose parts i.e. lug nuts, driveshafts, engine and tranny mounts, suspension joints and U-bolts.
Inspection sticker up to date.
Spare parts:
Tie-rod end
Engine belts
front and rear axleshafts
Front axle U-joints
Driveshaft U-joints
Spare tire (same size as others currently on truck)
Spare locking hub or set of drive flanges
Spare bolts of common sizes found on truck
Fuses for your truck
Radiator hose
Electrical crimp tape
Valve cores
Lug nuts
Lubes:
Oil
Power-steering fluid
Brake fluid
Automatic tranny fluid
Gas
Foram a gasket or RTV silicone
Water
Gear oil
WD-40
Tools:
Screw drivers
Wrenchs both standard and metric
Socket set both standard and metric
Adjustable wrenches
Jack
Allen wrenches
Hacksaw
Eletrical tape
Duct Tape
Misc tools
Recovery gear:
Winch
Winch control
Shackle or two
Spare cable (especially if you see yourself doing really long winch pulls)
Chain (grade 70)
Snatch block
Hi-lift type jack
Pull-Pal recovery anchor
Shovel
Ax
Tree protector
Snatch straps
Gloves
Winch bag
Old blanket or something similar to cover the tow strap or winch line to keep it from causing injury or damage should it break.
When troubleshooting for the cause of a blown fues, try conneting a light across the fuse terminals rather then installing a fresh fuse. If it takes awhile to find the short, you could go through a lot of fuses. However, if you use the light bulb technique, the light will simply illuminate until the short is repaired and the flow of current is halted. If the short is intermittent, you may find that the light flickers, when the bundle of wires is wiggled, giving a clue to the location of the short. If the light is not visible from where you are working, try using a buzzer.
Over time, grit from water crossings and desert dust blasting wil cause premature wear to alternators, especially those mounted low in the engine compartment. To extend the life of your alternator, use an electrical cleaner, available at most auto part stores, to clean the alternator after each off road outing. It takes only a couple of seconds, but it could add years to teh alternator's life.
Before installing a new oil filter fill it first, if possble, so that the engine will have oil pressure immediately upon start up. Of course, if the oil filter is mounted horizontally, you will not be able to do this.
Momentum, not speed, will get you you up ledges and hills and through deep mud holes. Knowing the amount of momentum needed without going too fast depends on the obstacle. This knwledge is priceless, and it comes only with experience. When you are in doubt, watch someoen else and learn from them.
Hills should be approached as straight on as possible. Keep all tires on teh ground by going only as fast as needed. Maintain foward momentum with steady throttle. Reduce pwer if your 4x4 spins the tires excessively, starts getting sideways, or beings to wheelie over backwards. Do not hit the brakes if you think you are wheeling over.
When backing down a steep hill especially if your truck has ABS, it's sometimes better to use the automatic transmission then brakes. Keep the truck in drive and let the vehicle freewheel backward, tehn apply throttle when you wish to slow down. This also works when driving in forward and descending steeps hills, except you'll want to place the tranny in reverse.
If the engine stalls and the tail pipe is submerged during a deep water crossing, don't try to restart the engine. As a precaution, have a buddy pull your vehicle back onto dry land. There you should remove the spark plugs before turning over the engine. Water doesnt' compress and if you crank over the engine when a cylinder is full of water, servere engine damage will result. With the spark plugs out, turn the engine over a few times and water will be ejected without danage. Also check the oil and air filter before continuing.
When winching, place an old jacket, blanket or towel over the cable closest to the vehicle you are recovering. If the winch cable breaks or comes loose from the anchor point while under tension, it can fly back into the winch vehicle as high speeds. However, with an object such as a blanket on the line, it will be slowed dramatically and will be less likely to whip back and hurt someone. Never stand near the cable. The same applies for tow straps.
The pulling power of a winch can be doubled by doing a double line pull. You'll need a winch accessory kit to do this. The cable is run frm the winch out to an anchor point, where it will pass through a pulley and back to the vehicle. This will double the pulling power of the winch but will cut the speed that the vehicle is moved by half.
The pulling power of a winch can also be tripled by doing a triple line pull. This is done almost the same way with the double pull except that you use an additional pulley which is located on the truck itself. You route the cable to the first pulley like in the doubl line pull then back to the truck where it gets sent through that pulley then back to the D-ring that is holding the first pulley and tree saver. The mechanical advantage of two pulleys doubles the puling power as well as halves the effective recovery spped. While effective, this method should be used carefully as twice as much stress is placed on all mounting points.
If you get stuck in the mud wthout a winch, wrap a tow strap around the tire closest to the direction you want to go and attach the other end around a nearby tree, 4x4, or other heavy object. Bring the strap out from the bottom of the tire. Leave a little slack and gently start to drive in the direction you tied yourself to. This slowly wraps the tow strap around the tire and makes a makeshift winch. Just be very careful not to get it caught on anything underneath your vehicle. Don't use much, if any, throttle, when doing this. This works great in mud, but your truck must be lined up straight with the tow strap and the anchor point.
If you're stuck in the mud wtihout a winch or anything to hook a winch to, put your rig into reverse adn expose some of the rut in front of your tires. Once you have a portion of clear track, pour a bag of Kitty Litter into the ruts. The water from the mud will mix with the kitty litter and dry into a miniature concrete slab, which might give you enough grip to get out.
It's best to shift into 4wd prior to becoming stuck. Sometimes after you get stuck, it's difficult to get 4wd to engage if the rig isn't able to move slightly. (This of-course doesn't apply to the Next Gen X's as we are able to shift into 4wd sitting still. :la: ). Plus, if you're only in 2wd you might be tempted to drive faster to make it through rough sections. Bashing through these sections put unnecessary strain on the vehicle as well as tearing up the trail.
When driving over rough terrain, it is sometimes difficult to hold your throttle foot steady enough to prevent having a bouncy foot on the accelerator. To prevent this problem, press the side of your foot against the tranny hump. This will create enough friction to allow for good throttle control.
Don't let anyone attempt to pull your badly stuck truck from to great of an angle. Frame damge can occur if they have to snatch hard. The steering system can also be easily damaged if the vehicle is pulled in this manner. The same goes for winching at great angles.
When fording deep water, enter slowly, and then gain a fewe miles per hour of extra speed. Back off the throttle slightly and then retain the original speed. This will creat a bow wave in front of you and dramatically lower the water level in front of your truck. This minimizes the risk of water drowning the engine. Apply the brakes once out to dry them so they will be ready when needed.
When driving off road, hold the steering wheel with your thumbs out. So if the front tire hits an on trail obstacle it is possible for the impact of the front wheel to jerk the steering wheel from your hands. If you have your thumbs to the inside, a spoke could wack them, causing unneeded pain or worse. By keeping them on the outside of the wheel, you'll reduce the risk of getting a broken thumb from a steering wheel spoke.
Reseating a tire bead on the trail is always tricky after a tire repair. A nylon, winch type, hold down strap can be a lifesaver. One can be placed around the center of the tread and tightened to reseat the bead. Ensure that the bead adn rim are free of mud and other debris. Also another way but more risky is lighter fluid and a match.
Tow straps are ver important but carry both a short and long one. Always get a strap that are rated for at least twice your vehicle weight. Remember that you might have to pull a friend's vehicle that is heavier the yours and always buy one without the metal hooks.
Engine oil
Tansmission fluid
Brake fluid
T-case oil
Diff oil
Belts
Spare parts:
Tie-rod end
Engine belts
Front axle U-joints
Driveshaft U-joints
Radiator hose
Valve cores
Lug nuts
Lubes:
Oil
Brake fluid
Gas
Water
Gear oil
WD-40
Tools:
Screw drivers
Adjustable wrenches
Jack
Allen wrenches
Hacksaw
Eletrical tape
Duct Tape
Misc tools
Recovery gear:
Winch
Winch control
Shackle or two
Chain (grade 70)
Snatch block
Hi-lift type jack
Shovel
Ax
Tree protector
Snatch straps
Gloves
Winch bag
