1 - 4 of 4 Posts
Looking to lift the 2wd X for mostly appearance reasons.
with the 275's it looks kinda squatty.
What of the 05+ lift options does anyone suggest.
as stated all the 4wd stuff will work with the 2wd but 2wd have the additional option of the 4" CST spindles available from, prg, performancelifts, etc.
I've been running them for about a year with no trouble. mine is set-up strictly performance minded with the titan control arms, brakes, hubs etc. but using just the spindle to replace the stocker will give you the look while maintainig completely factory ride... not to mention ditch the crappy cast spindle.
mine are the titan spindles but the xterra/fronty are exactly the same aside from the hub diameter. They run about $700 and you could do an AAL+ shackle in the back for a level ride
http://thenewx.org/phpbb2/viewtopic.php?t=2496
1 - 4 of 4 Posts
