Thanks for the uber fast reply!
Couple more questions to bug ya with:
Prep- did you do the usual degrease, sand etc? Or anything special?
Liner- is this the roll on type? How did you apply? Where bought? How much needed? Will it touch up ok ya think?
Thanks again for the info. I’m hopefully going to spruce up my ‘10 soon and finalizing what to actually use for the project.
I bet yours is gonna look damn good.
Prep:
-Washed panels on the X ahead of removal wish Dawn dish soap.
-Removed panels.
-Washed backsides of panels with Dawn.
-Sanded plastics with 120 grit paper
-Wiped panels with lint free cloth and acetone
-Sprayed panels with UPOL plastic adhesion promoter (available on Amazon)
Liner is of the spray on variety, but per the instructions you can also roll it on, and you’ll need at least a 2 gallon pancake compressor. HF has some for like $50 but I needed a new compressor anyway so picked up a 6 gallon one.
I purchased the 4 quart kit with spray gun on Amazon for $130 but they also sell it at Autozone. I think it’s like $30 more though. I only needed 2 quarts for all the bumpers and side plastics. It took 2 full coats a third didn’t appear to be needed but YMMV. Liner was sprayed at 60psi and allowed to flash for 30-45 minutes between coats. Instructions say an hour but it was warm out so it dried faster. The higher the PSI the finer the texture so you’ll want a test panel to play around with before spraying the panels.
Edit:
Forgot touch up: should touch up fine. Raptor makes a 2k aerosol can (it’s not cheap at $40 a can) but I suspect it’ll do a fine job a touching up if needed. That being said this stuff seems pretty durable. Full strength is after 7 days per the spec sheet and I just went out and hit the test panel (wasn’t prepped at all) with a hammer to test the durability and one tiny flake popped off.
