1 - 8 of 8 Posts
I want these Tires but I dont want any mods am I going to be Ok yes or No :geek:
Yes, but you could ALSO be OK with 285/75/16's, instead of 285/70/16's.
:D
Is that what you meant? (The '70's are small...the 75's are only using 1/2" more room than stock options)
:D
well he (I am guessing here) has the S edition.... so he is upgrading from 265/70/16 to 285/70/16 sure he can upgrade a little more but since he doesnt want to do anymore mods i am guessing he doesnt want to do the heat gun thing (even though it is easy)
Why not just upgrade to the Off Road sized tires 265/75/16???
last i checked they dont sell any 285 70 16's in anything you would want to use off road
i think there are a few street SUV tires that come in that size, but nothing else
i was interested in that size too becuase it would be the same diameter as the stock OR tires but a little wider
Discussion Starter #7
I dont like the skinni tires
so that means that the 285 75 16 need a mod of a torch , that sucks :bom:
Re: I dont like the skinni tires
No, it doesn't.
:D
SOME people find that a little bubble shaped protrusion molded into the plastic wheel well liner can rub on the inner edge of the tire...there is nothing behind the bubble, and it appears to be molded in as part of a feature that is needed on other models, etc.
If you have the bubble, and it is also hitting (They do not always rub...), THEN you can either take a blow dryer, and shrinck it back, or just cut it off with a razor knife, etc...a few minutes of work to take care of both sides, IF you are one of the people who NEED to.
:D
There are people with 305/70/16's as well btw.
1 - 8 of 8 Posts
