1 - 3 of 3 Posts
I have searched every post and thread I can find for weeks and I'm hoping someone can help. I put the info in bullet points to skip the lengthy narration.
2015 Pro-4X Rockford Fosgate System
  • Upgraded Radio to Atoto Pro 6
  • Used Metra 70-7552 and the RCA cables from Metra 70-553
    • Removed speaker pins for RCA's from Metra 70-553 and swapped them with the pins on 70-7552 (don't know if anyone has done this before, but it worked fine, if anyone has questions let me know and I can elaborate)
  • Wired up radio
  • Audio and radio work great, but no Subwoofer
  • Reviewed electrical diagram from Xterra Manual and I can't find what I'm doing wrong or how to correct
  • What I know:
    • RCA inputs on radio send a lower power signal that the amp needs, versus using the preamp high output from radio to speak wires; so I can either use the RCA inputs or I need a Line Out Converter, I opted for the RCA's, but my understanding is they are equal options.
    • Aftermarket Radio has Subwoofer input RCA port, but the Xterra wiring diagram, harness and amp do not show or have a subwoofer input.
    • Electrical Diagram shows speakers (FL,FR, RL, RR) going from the radio to the amp, then the amp sends out signal to speaker FR, FL, RR, RL and SUBWOOFER
      • So if the factory setup goes radio to speakers to amp to speakers and subwoofer, I have everything correct but no bass.
  • Attached is a diagram I made trying to illustrate my question... no need to make fun, I know it's terrible, just want to provide as much information as possible for a solution.
If you made it this far, thank you.
2015 Xterra Pro-4X
I’m curious to know about rewiring the harnesses. I took my ‘15 Pro-4x to an installer. I have a joying android unit that I wanted to install. He told me he to bypass the amp using the 7553. That was the only way it would work. I thought something was fishy when he said that.
Are you getting any bass at all, or just not from the sub?
You should have looked for my write up. You needed to use the 7551 harness. The other harnesses don't have the right connections.
1 - 3 of 3 Posts
