1 - 5 of 5 Posts
What are my options? Do I have any? The cover plate over the radio also covers the HVAC controls. I really want an AUX port,.. is there a way to add one to this radio? Thanks in advance. I did search, but couldn't find anything with this specific radio.
http://www.thenewx.org/forum/showthread.php?t=56706
Keep searching the forums. Some of the versa ' s came with an aux port. If you can find a versa radio with the aux port (search the interwebs and this forum). You can find one that is plug and play with your rig. There's a thread on the forums discussing it and has all the info you need. Try the "how to" section
Discussion Starter #4
Thanks for the quick reply!! I didn't know that trim piece existed. I may look into a double din Kenwood.
Sure man, no problem. Check out Metra for double din faceplate kits. They also sell the adapter harness you'll need in order to run and aftermarket head unit
1 - 5 of 5 Posts
