2011 Xterra X
15464 Views 43 Replies 13 Participants Last post by  ccg1018
I've since sold the X - hopefully the new owner finds it one day and is like... wait a minute!
Intro Comments: Base model but not basic.
Username: ccg1018
Xterra's Nickname: tbd
Year: 2011
Trim: X
Color: Avalanche White
LEGEND:
[+] Done
[*] Done but removed, upgraded or didn't work out
[-] Wanted
[/] In Progress
OWNERSHIP
[+] TITLE IN HAND (completed Feb 2020, purchased Feb 2017 - don't finance folks it is stupid)
[+] 2.0 PRG Aluminum Frontier/Xterra Coilovers setup for SPC UCA's and 700lb springs
[+] PRG 2.5 Dual Leaf AAL Pack
[+] SPC Performance UCA - 25540
[+] Bilstein 5125 Shocks
[+] PRG Ubolts
[+] Moog K80276 Cam Bolts
Wheels/Tires:
[+] 16” Vision 375 Wheels
[+] 285/75R16 GoodYear Wrangler Duratrac ordered 5/13/19
[*] 265/75R16 GoodYear Wrangler A/T + Kevlar - on vehicle when purchased
Engine/Misc Mechanical Parts:
[+] Volant CAI
[+] Bullydog 40417 (WOT Disable, 91 Tune, Idle up 250 RPM)
[+] Hella Horn Upgrade
[+] Magna Flow SS 12580 Muffler (video with exhaust note)
[+] Nissan Hood Strut Kit, Hood Rod Eliminator
[+] Off-road Gorilla Battery Hold-Down
[ - ] ARB Twin, 12 Volt, Onboard Air Compressor
[*] K&N Drop-In Air Filter
Drivetrain
[ - ] Lokka regeared to 4.10 in front (auto locker)
[ - ] M226 with E-Locker, geared to 4.10
[ + ] HardCore OffRoad PA LLC Front Bumper powdercoated w/ full grill guard and fog lamp holes and rad skid plate
[ + ] MaxArmor Gear (Maxterra) Rear Bumper
[ + ] OEM P4X Engine Skid Plate
[ - ] WhiteKnuckle Sliders powdercoated w/ side step bend and diamond plated rear
[ - ] TBD full under-body skids
Lighting:
[+] HIDProjectors.com Headlights With Monster Shrouds
[+] Baja Designs Squadron Pro Driving Combo
[+] Max Gear Armor (Maxterra) Ditch Light Brackets
[+] 30" AuxBeam Lightbar mounted to rear of custom drop-in basket
[+] OEM Style Amazon Fog Lights (installed on HardCore Bumper)
[+] Oxilam LED fog light bulb
[] F16 AuxBeam LED Headlights
[*] 20" AuxBeam Lightbar and mounted to OEM license plate frame to be removed
[+] Custom drop in roof rack
[+] Raingler MCN Cargo Net
[+] Upgraded to 1A power mirrors from manual OEM ones
Recovery Gear:
[+] Badland 9,000lb winch
[+] GearAmerica Shackles
[+] MotorMic Recovery Strap
[+] Reese Carry Power Tow Strap with Hook
[ - ] X-BULL Recovery Traction Tracks
[*] Dual front OEM Recovery/Tow hooks spray Painted Red (removed after bumper was installed)
[+] Suction Cup Ram Mount
[+] Upgrade to Sony XAV-AX100 6.4" w/ Apple CarPlay
[+] Nexar Dash Cam
[+] OEM Power Mirror Switch
[+] OEM Turn Signal Stock with fog light switch
[+] 3D MaxPider All Weather Floormats
[+] RoXterra Driver Side Window Molle Panel
[+] SUNPIE Universal Black Seat Cover Case
[-] OPT7 4pc Kit Aura PRO Bluetooth Smart-Color LED Strip Interior Lighting Kit-4pc-App Enabled-iOS & Android
Comms and navigation:
[+] Cobra 75WXST
[+] Cobra HGA 1500 Hga1500 36 Inch Magnetic Mount CB Antenna Heavy Duty Magnet
[*] Firestik Antenna, 4ft
[*] Diamond Antenna K400 Trunk/Hatchback Mount
[*] Custom Antenna Mount Bracket
4/10/2021 Updated Photos
135082
135083
135084
135086
02/01/2020 updated photos
How she came home in 2017:
  • Like
Reactions: 2
1 - 20 of 44 Posts
Lookin' good! Always liked the white Xterras- kinda regret getting the night armor as it's so common of a color.
Keep us posted on your suspension!
Made an update to the main post as to what I would like to make this rig more Overland/Weekend Warrior friendly. Most notable finished addition is a cheap LED light bar, nothing extraordinary but for around $50 I'm happy with something that gives me much better visibility on the trails and overpowers my headlights quite a few times over. I didn't like the idea of drilling into my bumper for it, so I purchased and over-priced bracket that hooks into the license plate frame from Amazon. The bracket and light are solid, I'll have to work on getting the OEM license plate bracket mount to not rattle as much off road, works fine on pavement, where you can't use the lights. ;(
So far, I've done a couple of drive thru car washes with no problems to the light and just returned from a 660 mile journey to and from the grand canyon and a few other attractions around Arizona without a hitch.
I'll be changing fluids in my engine/transmission to be safe as I've put about 3,000 miles on the vehicle since purchased and haven't a real idea whether the dealership I purchased from actually did anything they claimed they did.
I liked this recovery shackle from Amazon (link in main post)
Did a CB radio install
Got around to installing that right side tow hitch, had to trim the skid plate a bit to get her done. I decided on painting both of them red because it would be more hi-vis in a recovery situation and could save time.
Do you have any better pictures of the light mount?
I used an Amazon mount, not the greatest, it actually lost it's color and is a rustedish color now because the finish faded quickly in the 100+ degree summer. It is pretty sturdy, but the license plate mount is not the strongest so off road it jumps around everywhere, on road not really that big of an issue. Linked below:
iJDMTOY Miniature Front Bumper License Plate Mount
  • Like
Reactions: 1
Hey man love the build. Looks like there are other options for the bracket for example https://m.ebay.com/itm/2017-Bar-Fro...ight-Holder-OffRoad-/262987684805?_mwBanner=1. Why did you end up with a 20” Bar and not something bigger?
Also, your recovery shackle what’s the distance between the pin hole to the shackle hole? Looks like it sticks out a couple of inches. I’m on a quest to find a short one for the x.
On the mount I purchased, I expected the black finish to fade (I mean it ships free and is made somewhere with cheap materials and cheap labor). I'm also not a personal fan of that look, but if you are consider if you'd be willing to repaint it? If you are, consider how much of a damage multiplier the thin aluminum would be if you're involved in any sort of minor fender bender as it would likely just bend in on itself.
The 20" Auxbeam fit my needs:
1) My wife liked that it was only $38
2) Way, way brighter than my headlights
3) Small Enough to mount and not draw too much attention
In future I am looking forward to getting some Gorilla brackets to mount a 40" or 50" light bar on the roof.
In terms of the hitch D-Shackle, I wanted something that was pretty stealth as well when I was shopping around, I can't tell you specific measurements off the top of my head, but when you see these things in person you realize why they stick out a bit:
1) They need to clear the hitch
2) The D-Shackles needs to articulate
3) You need room for the D-Shackle Hardware
4) You'll likely put the stress of the weight of either your vehicle or another on it (it's not gonna be that small)
All in all however, they are a great alternative until I drop the $400 on a steel bumper with recovery points built in. This one is constructed of solid steel, so I feel a little better knowing that if I'm rear ended at a light somewhere it's somewhat protecting my rear bumper which is cheap and plastic-y.
Cool. Makes sense on both counts. I want to dabble with a small lightbar as well. I don't have time to cut into the bumper to mount it "inside the mount".
The shackle argument is interesting.. there's a 4runner at work that has the recovery point pretty flush with the hitch. I'll snag a pic.
If it is close to what I paid for this one, I might consider grabbing one.
Now that I’m back on this whole Xterra thing, I threw my Sony XAV-AX100 head unit in and combined it with one of those USB outlets that replaces a cigarette lighter - this works perfect for me because the X trim cake with a cover here where as the higher end models came with an AUX port.
I still have a backup camera for when I hook up a trailer. I want to do it only once and that will require probably a couple of hours to run the cabling properly. So it’s on the schedule for next weekend.
And then I pulled the trigger on 33' tires!
The UPS man came knocking with stuff yesterday. This time in the flavor of 285/75R16 DuraTracs. Here are come photos of me staging them, then the installation and some mall crawling poses.
  • Like
Reactions: 1
Looking good!!!
Do you happen to have a link for that bezel on the head until the gap on mine is driving me crazy
Sure thing, here’s a linkeroo... I’m not a fan of this kit. The harness was straight forward but the bezel itself is brittle and although it might look okay in the photo, is actually very brittle and the gaps are there because the face has never really snapped in the the right way.
Oh and if you don’t have an X trim and your X is newer, I don’t think this kit will work for you.
https://www.amazon.com/dp/B07DHF8Z9M/ref=cm_sw_r_cp_api_i_4CZ3CbT4EAPS1
Edit: forgot the link
Had the order I placed for my HC bumper on late 09/02/2019 evening and what do you know? Mid day on 10/3 it was at the terminal for pickup. I installed along with a HF Badland Winch along with some factory style fog lights.
I was very surprised when a very good deal popped up on Instagram and I was able to purchase one of Dave's bumpers for a heck of a deal -- I was very hesitant at first due to some financial concerns we recently had, however, my wife talked me into pulling the trigger with this.
Now that AG allowed us to, I edited the links and list above so that is as accurate and I can see just how much of a money pit things great hobby of ours is. Couldn't be happier.
123547
123548
How's your front suspension holding up with that bumper & winch? I see you still have stock springs on your coilovers per your build thread
Looks and feels the same to me to be honest. I’m sure it’s sagged some, but still works for me. The approach angle has been vastly improved and the 33’s fit fine in the wheel well.
hmm this is enticing because I plan to purchase the HC off road bumper too, but always felt as if I needed to upgrade to stiffer springs to deal with the weight. Thanks for your answering though!!
1 - 20 of 44 Posts
