1 - 10 of 10 Posts
For 35 12.5 15r
4.10 how many km/h
4.56 how many km/h
My 2008 nissan frontier (navara d40) vehicle
Dyno test = 174 km 4450 rpm
Tire = 33 12.50 15r
Ring pinnion = 3.69
Im change tire 35 12.5 15r
sometimes highway sometimes mountain
Ring and pinnion ? 4.10 ? v 4.56 ?
Thanks ?
I'm from Turkey ??
TNX Veteran
I'm not sure I understand your question.
Since you currently have 3.69's I assume you also have a manual transmission. Which means at highway speeds (120 km / hour) your current RPM's with 3.69's and 33" tires should be about 2200 - 2500 give or take. Running 35's and 4.56's you'll likely be in the 2500 to 2800 RPM range.
For what it's worth, my good friend just installed 4.56's in his manual Frontier and he is only running 33"s.
Discussion Starter #7
My 2008 frontier
( 2.5 L 4X4 4 cilindir 174hp motor 6 manuel dyno test = 33" tire 108mph {174 km} 4450 rpm
stock 3.69 ring and pinion )
35" 4.56 = last speed mph?
35" minimum 4.10 = last speed mph?
I don't want to go slow on the highway
I'm researching this
TNX Veteran
There are tire size and gear calculators all over the internet. Sounds to me like that's the research you need to do.
It also sounds like you intend to drive this thing a over 100 MPH..... Not something I'd do... Good luck in your search.
1 - 10 of 10 Posts
