1 - 6 of 6 Posts
I just got my first xterra which seems to be in great shape. i loooveee it, it’s a 2006 and it has about 126,000 miles and all around no great concerns except the potential of smod i have seen that these cars are prone to, but I see on the service records of the car that the transmission and propeller shaft was serviced at 85,000 miles, and then a reconditioned transmission with rebuilt torque is also on the service records at 110,000 miles. so my question is, should i be concerned of smod?? has the problem been taken care of, or should i still play it safe and install the new radiator and new lines and such? i’m not super familiar with cars but want to take the best care of it that i can. thanks for any response!
You have questions which only you can answer, but maybe I can help a little.
First, SMOD is the result of a faulty radiator.
Check the top of your radiator and determine if it's a Calsonic radiator.
If not, your fear of SMOD is over.
If you have a Calsonic radiator, look for a part number (should be a sticker) and compare the number to those listed on the link below
If your radiator is associated with SMOD, perform a radiator bypass until you can swap your radiator.
Just because your X has 126,000 miles on the current radiator does not guarantee SMOD cannot happen tomorrow.
Ps, if you plan to swap your radiator, swap your coolant hoses and the transmission lines at the bottom.
The trans lines tend to be overlooked , but they can become brittle and burst at the most unfortunate times.
Yes, I'm speaking from experience 05 Titan.
When i go to look for the transmission lines, what specifically am i asking for? I have gone to multiple car stores and no one has been able to help me determine exactly what it is i need when i ask for a transmission line and tells me to do a little bit more research.
i finally was able to get some help and better understanding on all of this at an autozone and find all of the needed parts. thank you for the response
I'm sorry I couldn't respond sooner.
Today has been rather hectic to say the least.
I'm glad someone at the auto parts store was able to assist in answering your questions.
  • Like
Reactions: lacozy
1 - 6 of 6 Posts
