1 - 4 of 4 Posts
Do I need to get the 2-4" rear shocks with the 2" PRG AAL and 2" shackle? I'm assuming so, but just didn't want to run into an issue with the rear shock being too short. I will also be relocating my rear brake lines as well (putting in a 2+" spacer).
Thank you,
Sn0
I would go 3-5"
I wouldn't.
This is what I did. I regret it. The radflo 2.0 set at 3-5" bottom out like crazy with AAL and Shackles set at low setting.
Of course you could crank the shackles to max to give a bit more but unless you can match that up front...
If I could do it again i would get 2-4 or even 1-3 inch shocks and not the 3-5. They are simply to long for an AAL and Shackle setup.
1 - 4 of 4 Posts
