1 - 20 of 20 Posts
2006 OR 6MT, OME Lift, SPC UCA's, BFG KO2's
Well, I just joined the club. Picked up an 06 OR, 6spd, 104k, Cooper Discoverer ATP's. Got a passing grade from the local Nissan dealer. Only negative marks on the Carfax was a failed emissions test in '16. I'll be the 3rd owner.
To my knowledge it has OEM TC/Tensioners, and Cats. How worried should I be of this/should I replace preemptively or wait?
I plan to change all fluids this coming weekend (its a new to me ride and cant hurt) and replace plugs and wires within the next 5k miles (per dealer inspection recommendation).
What else should I be keeping an eye on as far as normal issues that pop up around that 100k milestone. What should my first mod be for light back country driving here in CO?
Discussion Starter #4
Pics will be coming tomorrow. She is a bit dirty from the rain we just got so I gotta pretty her all up for the "before" photoshoot.
Welcome! That's a fine year of X you have there, low miles for the year too.
The three things that matter most for keeping your X among the living are the radiator (replace to prevent potential fluid mixing from an early model defect, aka SMOD), I replaced mine at 114k. The timing chains will let you know gradually that they need attention, the noise starts off as a light supercharger-like noise that you hear sometimes and eventually will be loud and present all of the time except at idle. Any dealer can confirm it for you, by now they've probably done hundreds of these repairs. The dealer my brother worked at said they did the timing repairs every single day with a new truck. The third thing is the catalytic convertors. They are placed VERY close to the exhaust valves, they might as well be part of the headers with how close they are, if the cats fail and the ceramic breaks up the VVT (emissions speak for the engine pulls a bit of the exhaust back in on every stroke) the dust gets pulled in and usually destroys the rearmost cylinder piston rings. It's happened to a few people on here and they usually have to swap a new engine in.
Other than that it's all general maintenance, plugs are due at 100k, also we don't have 'wires' per say, we have coil packs. I'm not sure why they recommend replacing them all without having a current problem, I'm still running the originals at 163k, I just keep a spare in the cargo in case I have trouble out on the trails.
Awesome! It's a great community here, great honest support. Really happy with my 06 OR also and how it's performing. All the necessary costly stuff have been mentioned above, and no worries about SMOD in your case. Just take care of that clutch, perhaps go with better aftermarket later.
If you're planning to wheel it, get tires and sliders first, for grip and rocker protection. Believe me they will hit first.
Enjoy your ride!
Discussion Starter #16
Wonder how much it costs to get a 2006 from a dealer.
Sorry, just now seeing this reply. I paid just below 7k for it. May have been a bit high, but its a CO vehicle so no rust, and 4x4's hold their value out here insanely well.
1 - 20 of 20 Posts
