Jen.
Just wanted to see if you could make some contact with the guys over there at TC in regards to check to see if they can make a diff drop kit. The reason I'm asking is that Greg ran your UCA in conjunction with the Automotive Customizer's lift kit which they now include as part of their lift kits along with the 2" spacer. After installing his UCA it ended up placing the CV's at an extreme angle and from my guess lead to the demise of his front diff. Not sure if that's the exact reason of it yet but would like to see if there is any way to get a diff drop to get the CV's back into or as close to factory specs as possible.
Here's a pic of the CV's with the AC coil installed.
Here's a pic of the CV's with the AC kit and TC UCA with 2" spacer installed.
I'm not sure if the same result with just running the TC UCA in conjunction without the spacer. I know that it would be even more extreme if you ran the 3" spacer and the AC lift kit.
