I posted http://thenewx.org/phpbb2/viewtopic.php?t=1493 and got a lot of great feedback but no fixie fixie. I was wondering if anyone with an 06 OR MT could duplicate the noise I have to verify that noise is "normal operation" like the dealer said. Basically you engage 4 lo and in 1st gear, let off the clutch and then depress the clutch in a rapid motion as if you were trying to pop a tire up on an object but you can't roll over the other side. I hope that makes sense. Anyways, the noise I hear is a violent klakking like somewhat resembling a broken cv joint. The dealer claims it is just normal play in the transfer case to driveline connection!
