Second Generation Nissan Xterra Forums (2005+) (https://www.thenewx.org/forum/)
-   Powertrain & Driveline (https://www.thenewx.org/forum/11-powertrain-driveline/)
-   -   Koyo Radiator A2807 for $127.00 (https://www.thenewx.org/forum/11-powertrain-driveline/88433-koyo-radiator-a2807-%24127-00-a.html)
21SF 02-04-2014 08:58 PM
Just placed an order for the koyo radiator. Came out to 144.00 shipped.
Just a heads up for those in need.
http://www.carid.com/2005-nissan-xte...-11057703.html
Wanderer 02-04-2014 09:13 PM
Wow, cheap. Mine was closer to $170-$180 if I remember correctly.
Have fun with the install - it's kind of a pain. :)
21SF 02-04-2014 09:22 PM
You're coming to the mod day for the install right? Lol
Wanderer 02-05-2014 06:38 PM
Quote:
Not sure I can make it this weekend. Maybe at least stop by to meet a few of you but I doubt that even. Are you doing the radiator and the lift on the same day?
21SF 02-05-2014 07:36 PM
No the rad wont be here. totally separate.
hybrid90 02-06-2014 01:03 PM
Your stock radiator got busted or just going with a better one?
21SF 02-06-2014 01:16 PM
Just trying to avoid smod.
Bliss_X 02-06-2014 03:26 PM
Damn thats cheap! I thought I remember seeing them in the $3-400 range when I last looked....I may just pick one up....
Wanderer: did you notice a drop in engine temp after installing it? Only reason I'd get one is for extra cooling...my truck tends to get hot and I want to prevent overheating while wheeling in the heat.
T-REXterra 02-06-2014 05:35 PM
The pic doesn't show the tranny cooler. Is it included as well?
Sent from AutoGuide.com App
Wanderer 02-06-2014 05:41 PM
Quote:
I didn't notice a drop (my temp gauge typically sits just below the mid line) but I was never overheating with the original. Since the thermostat regulates the temp, even if the Koyo has better cooling I wouldn't see it since the first one was working fine.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
