Second Generation Nissan Xterra Forums (2005+) (https://www.thenewx.org/forum/)
-   Interior (https://www.thenewx.org/forum/13-interior/)
-   -   Storage Struggle and Poor Lighting (https://www.thenewx.org/forum/13-interior/275570-storage-struggle-poor-lighting.html)
13ADVX 05-10-2019 11:45 AM
I'm starting to work on customizing certain interior items and i'm confused a bit.
First off i have no overhead dome light in the driver section. my dome lights are overhead of the rear passenger seating and hatch.
-my plan for this is to pull one from a yard and install it in my headliner....i just thought it was weird.
Second, I've been lurking on the raingler (spelling?) roof storage setups and they all use bolts threaded in the headliner fasterners. I dont have any of the attachment spots expect for two push in headliner anchors. anyone else dealing with the storage struggle?
https://i.imgur.com/eE249iC.png
pic for sympathy lol
https://i.imgur.com/AIhCyun.jpg
Brunnie 05-10-2019 02:26 PM
Take a look at my build. I have the Raingler Ceiling net installed. What they show on their website isn't exactly how it is installed in the later years. They use the existing cargo hooks and the grab handles over the back doors. If you are going to get a ceiling net, I suggest that you get the mesh option. It keeps stuff from sneaking out between the straps.
As for lighting, you should have a light in the rear cargo area, one over the rear seat area, and a dual map light in the front seat area. Again, my latest mod was to the map lights, and it was the addition of LEDs.
MeHere! 05-10-2019 02:30 PM
Simple LED's from Amazon make a WORLD of difference in the cabin
JYakapucci 05-11-2019 01:03 AM
Quote:
I have picked up a set of the LEDs for the interior and they are on the list of things that I need to do on mine.
1stpalindrone 05-11-2019 01:52 AM
I'm fixing to get the Raingler ceiling net too. This is the third time I've heard to go with the mesh option..
Are the LED interior lights plug n play?
Brunnie 05-11-2019 08:28 AM
The ones I've seen are. My mod wasn't though.
General_Tarfun 05-11-2019 10:18 AM
You can upgrade the factory cargo light and it definitely helps a lot but the best thing to do really is add some more lights that are spread out around the cargo area. That way instead of one extremely bright light you have a more even illumination of everything. One thing that's nice about the X is there's plenty of space behind the interior plastics to install a small led and run some wiring.
Nissan really stopped putting in dome lights in the later year lower models? That's nuts they got that cheap.
BillySpivitz 05-11-2019 12:02 PM
I'm going to ask, are you sure you have an "S" model? Your wheels and other things look like you have an "X" model. If so then yes, you don't have the rear ceiling cargo hooks or front map light (or at least that was the case with my 2010 X).
For the ceiling hooks, you can buy them from the dealer or junkyard, or even better from someone like @Ramness who sources from junkyards all the time and puts them up for sale here. I have the X model, and this is what I did. The threaded holes are there in the ceiling, you'll just need to cut holes in the headliner. This is the trickiest part - take your time, measure twice, and then measure again. There are a few threads on here from people with tips/tricks on transferring the location of the mounting holes to the headliner. I rushed a bit and one of my holes is not exactly aligned, but you don't see it unless you are looking for it. Here's a post from my build thread: https://www.thenewx.org/forum/3668442-post23.html (Not really a how-to though).
As for the front map light - I also researched getting one from a junkyard, but all the research pointed to this being problematic in terms of the electrical. I can't remember the exact issues, but again there are a few threads with the details. I am currently still looking at options - varying from wiring a front light in parallel to the center light, to battery LED's up front, as others have suggested.
TDog98x 05-12-2019 10:25 PM
Having installed a LOBO shelf, lighting in the cargo area is just about non-existant now. Need to come up with some ideas to illuminate the cargo area...
Brunnie 05-13-2019 12:58 AM
Quote:
Look at my Build thread, Post number 18. That will give you the lights, then it is up to you to figure out what to do with them.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
