Second Generation Nissan Xterra Forums (2005+) (https://www.thenewx.org/forum/)
-   Gear & Equipment (https://www.thenewx.org/forum/29-gear-equipment/)
-   -   On Board HOT Water (https://www.thenewx.org/forum/29-gear-equipment/275018-board-hot-water.html)
Taylor Spaulding 04-11-2019 01:54 PM
On Board HOT Water
Looking around, and I was wondering if there have been any advances in on-board water.
I'm planning on getting myself setup with on-board air for adding pressure but if I want to get my partner involved in the great outdoors, I need a HOT shower.
I've looked at the heat exchangers and tbh I'm not sure if there's enough space to mount one in the X and I worry about my own technical skills rigging it up.
Has anyone got other good methods for onboard hot water? I've also considered a custom built application, which might be one way to go, utilizing the immersion heater from Rinsekit and a custom tank.
MeHere! 04-11-2019 03:06 PM
Taylor Spaulding 04-11-2019 03:12 PM
Quote:
Originally Posted by MeHere! (Post 4284096)
I just get taken back to this thread. Lol. I saw the one thread with the heat exchanger, but that's what I was wondering about
ChrisHaynesUSA 04-11-2019 04:29 PM
I use a Zodi dual burner shower.
With their 12volt pump off the car battery.
shower head can be placed back in water tank to recirculate until desired temp is reached , but I dont normally have to do that.
It is damn hot after dual burner heat exchange.
storage case doubles as water tank.
https://s1-ssl.dmcdn.net/AcjS7/x1080-eCv.jpg
https://image.sportsmansguide.com/ad.../119420_ts.jpg
https://n.b5z.net/i/u/10008036/i/12v...tery-Clips.jpg
Nasarno 04-11-2019 04:45 PM
Here is my OBW system: Onboard Water Tank
It works very well and so far served me in two camping trips, one of them 3 days and the other a whole week. It's not air pressurized, instead I use a water pump. It's still ambient temp water, but I've also got the heat exchanger and have some plans to make the proper bracket and install it in the engine bay.
jcco 04-11-2019 10:34 PM
I always wondered if that thing worked. Looks like it's pretty well made, but how much of a pain is it to set up, use, and tear down?
ChrisHaynesUSA 04-12-2019 12:25 AM
Hot shower.
Happy wife.
GeolJon 04-12-2019 11:59 AM
Probably not quite what you had in mind, but I've been eyeing one of these for a long time:
https://roadshower.com/
Price may seem a little high, but it's probably less expensive and complicated than burners, fuel, water pumps, and heat exchangers. And I doubt I would be using it in the wintertime anyway.
Taylor Spaulding 04-12-2019 12:01 PM
Would anyone mind running me through what it would take to install a heat exchanger? It seems like a fairly simple concept, Cold water in, hot coolant in, hot water out, slightly cooler coolant out. But I'm not really familiar with which hose on the radiator I need to splice into. I assume I could splice into the outflow to engine, and it would still be plenty hot. However, not ever having worked with the radiator before I am intimidated by the pressure and heat that might go through this system. I would love to hear how people go about installing these heat exchangers.
Nasarno 04-12-2019 01:05 PM
Quote:
As I mentioned, I haven't done it yet. Just planned and researched. Asking about where to splice, here was my question and peoples answer:
How To: Tap a Heat Exchanger to coolant hoses
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
