Second Generation Nissan Xterra Forums (2005+) (https://www.thenewx.org/forum/)
-   Member's Xterra (https://www.thenewx.org/forum/50-members-xterra/)
-   -   Vizard's Xterra - VK56 Swap (https://www.thenewx.org/forum/50-members-xterra/254138-vizards-xterra-vk56-swap.html)
Vizard 12-11-2017 11:38 AM
3 Attachment(s)
Intro Comments: Hello Everyone, I just got my Xterra on 12-9-2017 with 86k miles. It's completely stock right now. I'm going to change the radiator with an aftermarket one to prevent the SMOD issue. Eventually I will start offroading, but I'm new to this world so I don't even know where to start. I have a 2008 Infiniti G37 coupe and it's my weekend car now that I have the X. I'm addicted to modding my G37 since it has exhaust, test pipes, intakes, tune, air suspension, retrofitted headlights, carbon fiber hood/trunk etc. so I know the X won't stay stock for long *sigh* here we go again. lmao
Username: Vizard
Instagram: Mall_Crawling_X
Xterra's Nickname: Good 'ole Rusty
Year: 2005
Trim: SE 4x4 5AT
Color: Night Armor (K26)
Wheels/Tires:
-Pro Comp 89 17x8 -12 offset
-BF Goodrich TA KO2 285/70/17
-Melt Mod/minor trimming
Brakes:
-Raybestos Advanced Tech Rotors
-Raybestos EHT Brake Pads
-Power Stop Performance Front/Rear Calipers
-PRG Rear Diff Breather Kit
-Nisstec Stainless Steel Extended Brake Lines
-Nisstec MK84 Front Coilovers 550lbs
-NissTec 2” Add-A-Leafs
-Radflo 2.0 Rear Emulsion Shocks
-Mevotech UCA
-Mevotech LCA
-Front Camber Bolts
-Steel Axle Degree Shims
-Extended U-Bolts
-SPC UCA bolts
-Sony XAV-AX100 touchscreen
-Uniden Pro 520 XL
-4' Firestik FS CB Antenna
-18' Premium RG8X CB Coax Cable
-Heavy Duty CB Antenna Spring
-Firestik CB Antenna Quick Disconnect
- Raingler Ceiling Cargo Net (Mesh)
- White Knuckle Offroad Rock Sliders
- DOM tube steel
- Matte Black Powder Coat
- Angled 25 degrees
Lighting:
- None :(
Accessories:
- Smittybilt Rapid Air Deflator
- Raingler Seatback Handle x2
- Rotopax 2Gal Fuel Can
- 48" All Cast Hi-Lift Jack
-(2-3" adjustable tube mounts & Handle Keeper)
- Hi-Lift Jack NJC Neoprene Jack Cover
- ARB Awning 2000
- Fourtreks Modular Awning Mounts
- ARB Deluxe Awning Room
To Do List:
Switch Pro SP-9100 panel (on the way)
Roof/Bumper LED rocker switches (need to install)
Auxbeam LED Light Bar Wiring Harness Kit w/ fuse relay (need to install)
Auxbeam 20" LED Light Bar 126W (need to install)
40" Double Row LED Light Bar CREE - 400W 34,200 LUMENS (need to install)
ARB 12v twin On Board Air Compressor (need to install)
ARB Tire Inflation Kit (need to install)
ARB Digital Tire Inflator (need to install)
Wish List:
Gobi Rear Ladder
Headlight retrofit
ARB Diff cover (Red)
Undercarriage Rust Protection
Raingler Base Grip Rack Handle
HeftyFabWorks Front Tube Winch Bumper
Max Gear Rear Bumper with swing arm/tire carrier
Removed:
-OEM 17" SE Wheels (Plasti Dipped)
-Spidertrax 1.5" wheel spacers
-Side Step and Mud Flaps
--2.5" Rough Country (never installed)
Maintenance:
Replaced Radiator around 88k miles
Passenger Brake line needed to be replaced
Regular Oil Change at 90,783 miles (6-1-18)
Calipers/Brake pads/rotors at 92,982 (7-30-18)
Replaced Battery at 93,540 (9-3-18)
Oil Change at 95,000 (10-15-18)
Camshaft sensors, bank 1&2 at 96,971 (11-24-18)
Tie Rods 97,450 (12-1418)
Wheel Bearings Assembly 97,450 (12-14-18)
Wheel Alignment 97,450 (12-14-18)
Fuel Pump/Fuel Sending Unit 98,000 (1-3-19)
Oil Change at 98,910 (1-23-19)
VK56 swap at 100,350 miles (Feb/2019) picked up on 3-24-19
Transmission Fluid Change done with vk swap
Cooling System Fluid Change done with vk swap
Oil Change done with vk swap
Nisstec Stainless Steel Extended Brake Lines 4-20-19 (103k miles)
Oil Change at 108,500 (7-15-19)
VK56 SWAP PARTS
2010 Titan Engine under 120k miles
2010 Titan 4wd Transmission under 120k miles
2007-12 Titan Engine Harness (Used, Converted)
2007-12 Titan Engine Control Module
UpRev Tune
Titan Motor Mount Brackets
Titan Powersteering Pump (Used)
Titan AC Compressor (Used)
Titan AC Compressor to Condenser Line
Pathfinder V8 Low Suction AC Line
Titan Powersteering Pressure Line
Titan Engine to Transmission Bolts
Titan Flexplate (Used)
Titan Clutch Fan - upgraded to electric fan
Serpentine Belt
Titan Fan Blade (Used)
Heather Core Fitting
Titan Lower Radiator Hose
Titan Upper Radiator Hose
Pathfinder V8 Radiator Shroud
Pathfinder V8 AC Fan
Titan Coilpacks
Titan Transmission Dip Stick
Titan Starter
PRG Polyureathane Titan Motor Mounts
PRG Polyureathane Titan Transmission Mount
Titan Engine Cover
Airraid Air Intake
JBA Headers
Cajun Titan Resonated B Pipes 2.5"
Cajun Titan Y Pipe 2.5"
OEM Exhaust Gaskets
JBA Catback Exhaust
Red Silicone Coolant Hose Set
Vizard 12-11-2017 11:39 AM
VMBiohazard 12-11-2017 12:47 PM
Nice rides!
AlbatrossCafe 12-11-2017 01:13 PM
Quote:
Originally Posted by Vizard (Post 3999338)
I'm going to change the oil cooler with an aftermarket one to fix the SMOD issue. Eventually I will start offroading but I'm new to this world so I don't even know where to start.I have a 2008 Infiniti G37 coupe and it's my weekend car now that I have the X. I'm addicted to modding my G37 since it has exhaust, test pipes, intakes, tune, air suspension, retrofitted headlights, carbon fiber hood/trunk etc. so I know the X won't stay stock for long *sigh* here we go again lmao
Does anyone know what is the biggest tire I can put on my stock wheels without rubbing or needing to upgrade the lift? TIA
It is actually the whole radiator that you need to replace, not the oil cooler. Koyorad makes a pretty much identical one to OEM for about $125. Other people get CSF Aluminum radiators for 3-4x more if you need that capacity (most don't).
The biggest tire size is 285/75/R16 or 285/70/R17 (your stock wheels). That is a 33" tire. You can fit that without any lift, but you will need to melt the plastic of your fender liners a bit: https://www.thenewx.org/forum/15-how-...fit-*cpl*.html
Nice car. I usually am not a fan of Infinitis but yours looks awesome. I also knew nothing about 4x4, off road, or trucks really when I got my X a year and a half ago, but I've completely transformed it since then. Its really easy to get into and fun to learn. Seeing how you modded your car, I am excited to see what you do with the X haha.
Wilson06offroad 12-11-2017 01:22 PM
Derek covered all the bases there^. Canít wait to see what you do to your X if that Infiniti looks that good. And also, thank you for not camber-ing out the wheels ;)
Vizard 12-11-2017 05:43 PM
Quote:
It wont let me add links because of my post count
So add the radiator from amazon Koyorad A2807 Radiator and that will fix it? Or do I need the oil cooler as well?
AlbatrossCafe 12-11-2017 06:09 PM
Get it from FR Sport, some of the ones on Amazon have turned out to be Chinese fakes: https://frsport.com/Koyorad-A2807-OE...1_p_74067.html
You only need to replace the radiator. This post has a good description of the problem: https://www.thenewx.org/forum/11-powe...ml#post3631074
Try searching around on here. Most of the stuff you can think of has already been done and is on this forum somewhere...
Old Navy 12-11-2017 10:06 PM
https://www.thenewx.org/forum/8-welco...tions-faq.html
Old Navy 12-11-2017 10:07 PM
It won't let me add links because of my post count
You can now - You've been upgraded!
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
