Towing X With Four Wheels Down Behind an RV - Page 2 - Second Generation Nissan Xterra Forums (2005+)
post #11 of 19 (permalink) Old 08-27-2012, 06:05 PM
2007 Xterra SE
Brew's Avatar
Don't do it, as stated, they were not designed to be flat towed.
Brew is offline
post #12 of 19 (permalink) Old 08-27-2012, 08:06 PM Thread Starter
2008 Xterra Off-Road
frisbeekev's Avatar
Send a message via AIM to frisbeekev
Thanks for the info. I wasn't sure as I saw a frontier being towed 4 wheels down on my way to the beach, so I thought I would ask. Which I would have got a pick but they were moving the opposite way.
frisbeekev is offline
post #13 of 19 (permalink) Old 08-27-2012, 10:27 PM
2012 P4X
fyrftr007's Avatar
Read you owners manual, it is clearly stated.
fyrftr007 is offline
post #14 of 19 (permalink) Old 08-27-2012, 10:30 PM
ChrisHaynesUSA's Avatar
Originally Posted by gpzguy View Post
I burned out the synchromesh in a manual transmission car once towing it like that...I would never do it again without first disconnecting the drivelines...its just not worth the risk.
gpzguy is back!!!!
where ya been?
ChrisHaynesUSA is offline
post #15 of 19 (permalink) Old 08-28-2012, 12:03 PM
2008 Xterra SE
GPzGuy's Avatar
Originally Posted by chrishaynesusa View Post
gpzguy is back!!!!
where ya been?
In the last nine months I've been Going through a LOVELY 'uncontested' divorce...getting my sanity and life back on track, and rekindling a relationship with the woman who was the love of my life from before I ever met my ex....actually my very first girlfriend and the one who got away....life is good...I have my dignity, my Xterra, my motorcycle, my bicycles, my dogs, my daughter every other weekend and summers...and a smoking hot girlfriend who loves me for who I am.
GPzGuy is offline
post #16 of 19 (permalink) Old 06-04-2019, 10:29 PM
So, what changed between 2006 and say 2014? Is it still the same transmission and transfer case? Why was it OK in the owners manual to flat tow in 2006 and not with later models?
Eric Coulombe is offline
post #17 of 19 (permalink) Old 06-05-2019, 09:19 AM
2010 Xterra OR 6MT
Where does it say you can't on the newer ones? All I have ever seen is "NO" with an automatic. And "YES" with a manual, providing you run it every few hundred miles to lube the transmission.
early 2010 is offline
post #18 of 19 (permalink) Old 06-05-2019, 10:24 AM
I know my 2011 owner's manual still says I can flat tow my 6MT. Run it for two minutes, tow it up to 500 miles, repeat.
post #19 of 19 (permalink) Old 06-05-2019, 05:53 PM
From the Owner's Manual for my 2011 Xterra:
FLAT TOWING
Towing your vehicle with all four wheels on the
ground is sometimes called flat towing. This
method is sometimes used when towing a vehicle
behind a recreational vehicle, such as a motor
home.
CAUTION
● Failure to follow these guidelines can result in severe transmission damage.
● Whenever flat towing your vehicle, always tow forward, never backward.
● DO NOT tow any automatic transmission vehicle with all four wheels on the
ground (flat towing). Doing so WILL DAMAGE internal transmission parts
due to lack of transmission lubrication.
● For emergency towing procedures refer to “Towing recommended by NISSAN”
in the “In case of emergency” section of this manual.
Manual Transmission (if so equipped)
● Always tow with the manual transmission in Neutral.
● On 4-wheel drive vehicles, place the transfer case in the 2H range. Failure to do so will
cause the powertrain to bind up.
● After towing 500 miles (805 km), start and idle the engine with the transmission in Neutral for two minutes. Failure to idle the engine
after every 500 miles (805 km) of towing may cause damage to internal transmission parts.
Automatic Transmission (if so equipped)
To tow a vehicle equipped with an automatic transmission, an appropriate vehicle dolly MUST
be placed under the towed vehicle’s drive wheels. Always follow the dolly manufacturer’s
recommendations when using their product.
Brunnie is online now
