Pre-caution to be Considered after Supercharger Installation - Second Generation Nissan Xterra Forums (2005+)
  • 1 Post By Ibrahim11
  • 1 Post By kebler2005
post #1 of 8 (permalink) Old 05-12-2019, 10:37 PM Thread Starter
2008 Silver Lightning Xterra
I have doubt if there is additional part to be changed after supercharger installation such stock radiator and fans as well ,hence the heat generated by engine will be increase , also any information about the engine coolant temperature and and supercharger coolant temp to be maintained in high way and offroad , in middle east the ambient temperature is high , even though we are not able to succeed for V8 swap due to engine cooling issue , Any thoughts from experts?
Ibrahim11 is offline
post #2 of 8 (permalink) Old 05-13-2019, 12:03 AM
ChrisHaynesUSA's Avatar
get the JK hood louver plate
Stillen aluminum crank pulley
CSF aluminum radiator
silicon hoses
stay off skinny pedal till needed.
last supercharged rig I remember blew it up shortly after installation.
ChrisHaynesUSA is offline
post #3 of 8 (permalink) Old 05-14-2019, 12:09 AM
meanGREENnugget's Avatar
These engines were not designed for forced induction. The compression ratio is designed for naturally aspirated engines. If you do go this route you will likely blow your engine fairly quickly, and i can’t imagine it will run well at all prior to the final knock. Good luck.
meanGREENnugget is offline
post #4 of 8 (permalink) Old 05-14-2019, 02:02 AM Thread Starter
[QUOTE=meanGREENnugget;4291742]These engines were not designed for forced induction. The compression ratio is designed for naturally aspirated engines. If you do go this route you will likely blow your engine fairly quickly, and i can’t imagine it will run well at all prior to the final knock. Good luck.i have go through many opinion and reviews for the same , I do agree partially that engine not designed for induction force, but I think if the post pressure will be limited to 10Psi and the compression ratio will be changed to 9:1 also transmission pressure will control by uprev , it is shall work , hope so .
Brazos_bend likes this.
post #5 of 8 (permalink) Old 05-15-2019, 05:05 PM Thread Starter
Thanks guys for your advice, I have changed my mind for supercharger, for dunes brushing , the rpm is always more than 5k , so I guess the supercharger is not suit for this purposes hence the engine will be heated up .
post #6 of 8 (permalink) Old 05-15-2019, 05:36 PM
2010 Super Black Xterra Off Road 4x4 6MT
kebler2005's Avatar
VK56 swap.
emossel9 likes this.
kebler2005 is offline
post #7 of 8 (permalink) Old 05-15-2019, 06:11 PM
2008 Cayenne Red Xterra S 4x4
^^^^ That. Safer, more HP, and probably similar~ish cost maybe a little more (not exactly sure on that one)
emossel9 is offline
post #8 of 8 (permalink) Old 05-20-2019, 03:38 PM
2012 Xterra Pro-4X
OBXterra's Avatar
^ and more torque down low - where you need it for deep sand
I do miss my HEMI Durango for pulling out stuck Fords on the Outer Banks
2012 Pro-4X
Shrockworks Sliders & Bumper with Winch
BullyDog / aFe Exhaust / IM Spacer / K&N
OBXterra is offline
2006 OEM Fog Lamp/Fog Light Installation BarefootXterra Electrical 10 03-04-2017 06:55 PM
How-to: Habitat Offroad Rear Recovery Point Installation [email protected] How-to's 4 01-17-2017 11:34 PM
SOLD: Stillen Supercharger Xterra ChrisHaynesUSA For Sale 14 11-02-2011 02:02 PM
