Worst . Dipstick . Ever . . . - Second Generation Nissan Xterra Forums (2005+)
 11Likes
LinkBack Thread Tools
Old 04-05-2019, 12:42 PM Thread Starter
2012 Xterra Pro-4X
30+ years of various vehicles, lawn mowers, 3 wheelers, cycles, manufacturers, etc..
Never have I experienced such a worthless dipstick.
I may be over full or may be 3qts low, who knows. The damn thing repels oil so half the stick is clean from lo to hi.
I have tried several methods to get a clean reading with no success.
I am thinking about roughing it up with 100grit so the oil sticks to it.
Maybe it's just mine, anyone else experience this?
The tranny dipstick works like a dream, no ambiguity what so ever, not sure why that is so myterious to some what with the careful measuring of what was drained out.
End rant lol
funkierfawn21` likes this.
fatty is offline
Old 04-05-2019, 01:03 PM
Be thankful you didn't have a first gen.
Old 04-05-2019, 01:05 PM
I never check my oil (lol) but my mom's mini cooper had this same problem. She got a different dipstick that had holes it in it so you relied on the surface tension of the oil to fill the hole rather than require the oil to hang on the dipstick. It worked great and was SUPER easy to read. Maybe you should swap out with something like that?
Trip Photos Page -
"Mods first - life later."
Old 04-05-2019, 01:51 PM
Don
2015 Xterra
Yes! I've always hated the dipstick on my Xterra. It is very difficult to get in back in and I nearly kink the thing each time. Toyota sienna van has a dipstick that is even harder to see the oil level. Must of been designed by dipsticks.
Don is online now
Old 04-05-2019, 02:02 PM
2006 Midnight Blue Xterra Off Road
Roughening up the area between low and full should give you the desired result. I did this to the dipstick on the truck I drove in high school after taping it off and using a bead blasting cabinet.
timmytoast is offline
Old 04-05-2019, 02:13 PM
2006 Super Black Xterra X 6MT 2wd
Zack.'s Avatar
Could even drill holes in existing dipstick to make sure itís the right length and save a few bucks.
mtnbound and AlbatrossCafe like this.
Zack. is offline
Old 04-05-2019, 02:35 PM
Funny that's what I feel about the transmission dip stick, the engine oil one for some reason has never been a problem for me. One trick I learned after never being able to read the trans level was to lay the dipstick on a clean paper towel for a few minutes and then push it back on the towel without lifting it off. That always leaves a nice mark on the towel to see the level.
Old 04-05-2019, 02:56 PM Thread Starter
2012 Xterra Pro-4X
I'm a bit OCD and it bugs the hell out of me that I can't tell exactly what the level is when I change the oil.
I'm visualizing that it must lay in there at a sharp angle because no matter how fast I pull it out, the oil had slid of to the edge.
I'll scuff it up or get over it I guess, drilling holes(if done poorly) might be a place for it to snap off.
fatty is offline
Old 04-05-2019, 03:10 PM Thread Starter
2012 Xterra Pro-4X
On the trans stick I just pull it, "dry" it off, reinsert, pull it again and see where the glossy liquid starts. It does look clear on the stick so I always check it in the sun light.
The hatch pattern and slightly rough surface holds the fluid in place.
mtnbound likes this.
fatty is offline
Old 04-05-2019, 04:26 PM
JNR
JNR's Avatar
Never had an issue reading the level, although it can be tricky to put the dipstick back in.
Brunnie likes this.
JNR is offline
Transmission Dipstick Colour Question ? wolf73 General Xterra 6 07-09-2017 09:55 PM
No AT Dipstick on 2009 Xterra TitanUranus Powertrain & Driveline 13 02-07-2015 08:26 PM
How-to: AT Dipstick Bolt Mod steveg How-to's 2 11-07-2010 01:01 PM
***Warning***Stupid Question - ATF dipstick? DarkKnight369 Powertrain & Driveline 13 06-24-2010 01:00 PM
[SOLVED] How easy to read is the ATF dipstick? DePingus Powertrain & Driveline 3 04-08-2010 12:48 PM
