** The Dumb Question Thread ** - Page 87 - Second Generation Nissan Xterra Forums (2005+)
 323Likes
post #861 of 1020 (permalink) Old 12-07-2018, 05:21 PM
Originally Posted by Kalestrom View Post
Does it normally take a long time to switch from 4H to 2wd? It's really quick from 2wd to 4H, but it can take a minute or longer to go the other way around.
mine definitely takes longer to come out of 4H than to go in - but not a full minute. As mentioned your driveline needs to be slack for it to come out - so if your driving up an incline or something you might have to slip it in neutral, let off the gas - fiddle around with it sort of thing.
And x2 on change your fluid if you haven't in the last 30K miles.
post #862 of 1020 (permalink) Old 12-08-2018, 02:15 AM
2005 Avalanche White Xterra S 4x4
Kalestrom's Avatar
I've been fiddling with it to try to figure out what works, but I've only gotten it to switch quickly once. Definitely going to be taking a look at the fluid when I get a chance, I only bought mine a month ago and I don't think it's been changed any time recently.
Kalestrom is offline
post #863 of 1020 (permalink) Old 12-08-2018, 03:22 AM
Yes, it can take a while. 2wd to 4x4 has always been way faster than 4hi to 2wd on mine.
Originally Posted by Zack. View Post
Could the catalytic “rotten egg” smell also be described as a sour dog **** smell? Or did someone step in something before getting in?
Ammonia is the scent I get from bad cats.
aStrauss likes this.
post #864 of 1020 (permalink) Old 12-08-2018, 08:39 AM
2012 Avalanche White Xterra Pro-4X
cheapest bumper options, shrockworks is expensive (for me)
Cody is offline
post #865 of 1020 (permalink) Old 12-09-2018, 01:58 PM
RikRong's Avatar
Hardcore Offroad, most likely.
Sent from my XT1635-01 using Tapatalk
GDPearson likes this.
R. Long
Build Thread-->
SoCal Club Xterra -->
RikRong is offline
post #866 of 1020 (permalink) Old 12-10-2018, 03:13 AM
Kalestrom's Avatar
Wow I've been here with a lot of questions lately. Chances are this won't be the last though, ha.
So I have a problem, my driver's side power lock switch doesn't work, but the passenger side and key fob both work fine. All the windows work fine as well, it's just the one switch. Any ideas as to what the problem may be? Or is this truly a dumb question?
post #867 of 1020 (permalink) Old 12-10-2018, 05:16 AM
2007 Midnight Blue ❌terra S
TerryD's Avatar
There's a write-up somewhere on here about disassembling the power window switch on the driver's door and cleaning the contacts in there. You might start with that and see if that's the issue.
Beyond that, I've not heard of any one else having that problem.
Mildly Demented...
KT4OZ
Build Thread:
TerryD is offline
post #868 of 1020 (permalink) Old 12-10-2018, 01:16 PM
2006 Super Black Xterra X 6MT 2WD
Zack.'s Avatar
Do the non-elocker axle shafts (m226) work with the elocker?
Found the answer was at least 50% no from reading some other threads.
Next question - which side is the short axle?
Zack. is offline
post #869 of 1020 (permalink) Old 12-11-2018, 03:36 PM
Kalestrom's Avatar
Okay so I found the issue with the power lock. Somehow the contact slider is missing. I'm guessing it was taken apart to be cleaned by the previous owner and the piece fell out without them realizing? Either way, I'm just going to find a way to make a new one. With the help of my trusty 3D printer it shouldn't be too difficult.
post #870 of 1020 (permalink) Old 12-11-2018, 09:31 PM
Kalestrom's Avatar
So I got that to work! Although I found something else weird. It works perfectly, but when I turn the electronics on and when one or more of the doors are open, it quickly locks and unlocks. It is that specific about it too, if the door is closed or the key is turned to off, it works fine. It happens on both sides, so I don't think it has anything to do with my repair, would it?
Edit: Actually that happens on most cars to prevent you from locking your keys in... I can honestly say I didn't know that. Ignore my ignorance
