** The Dumb Question Thread ** - Page 110 - Second Generation Nissan Xterra Forums (2005+)
 453Likes
post #1091 of 1304 (permalink) Old 05-04-2019, 09:50 AM
Originally Posted by AdventureRider81 View Post
Delrin is the brand.
Negative, Delrin is the common name given by Dupont to the plastic polymer Polyoxymethylene, also known as acetal, polyacetal, and polyformaldehyde, is an engineering thermoplastic used in precision parts requiring high stiffness, low friction, and excellent dimensional stability.
Not unlike pharma companies do.
IM1RU is offline
post #1092 of 1304 (permalink) Old 05-04-2019, 10:34 AM
Haha I can see why, Polyoxymethylene sounds like something sold in little baggies in dark alleys.
IM1RU likes this.
post #1093 of 1304 (permalink) Old 05-04-2019, 11:52 AM
2011 Avalanche White ❌terra Pro-4X
AdventureRider81's Avatar
I stand corrected. Thank you for clarifying. Edited original response for future ref.
Build Thread
(StormTrooper Gretchen (big,white,fat,ugly,and German): 2015 BMW R1200GS Adventure White
AdventureRider81 is offline
post #1094 of 1304 (permalink) Old 05-04-2019, 05:25 PM
2015 Glacier White Xterra Pro-4X
kolsky's Avatar
Negative, Delrin is the common name given by Dupont to the plastic polymer Polyoxymethylene, also known as acetal, polyacetal, and polyformaldehyde, is an engineering thermoplastic used in precision parts requiring high stiffness, low friction, and excellent dimensional stability...
and they make excellent guitar picks!!
kolsky is offline
post #1095 of 1304 (permalink) Old 05-04-2019, 05:29 PM
Had a chance to look at it more today, the pass side sway bar link (mevotech) doesn't rotate so I removed the nut and put some brake grease behind the nut and torqued it a bit less than last time. Also the front pass camber bolt washer looks like it might be moving up/down some. There appears to be a slide mark or something right below the washer, the torque is ok on the nut but there's definitely some grease behind that washer. Probably from when I greased the lca bolts so they wouldn't sieze on me.
post #1096 of 1304 (permalink) Old 05-06-2019, 08:46 PM
Dumb question... I am trying to replace all 4 pads/rotors.
On RockAuto, do I need to order quantity 2 of brake pads for front & rear (4 total) or does quantity 1 include 2 sets of pads?
Trip Photos Page -
"Mods first - life later."
post #1097 of 1304 (permalink) Old 05-06-2019, 09:47 PM
One set should be for the front, or the rear.
IM1RU is offline
post #1098 of 1304 (permalink) Old 05-07-2019, 11:41 AM
What are the downsides of too much caster?
I'm pretty sure that I do at the moment but before lowering the angle I wanted to see what our group of Xterra scholars thought on the subject. When I setup my SPC's last year I set the caster adjuster to slot B or +2.75 degrees of caster. They note in the install sheet that slot D or +1 degrees of caster will return most truck to stock.
My main complaints are:
1. Overly strong pull to center. At 70+ mph on long sweeping freeway turns the truck doesn't want to turn, it's a fight to keep the truck in lane while also completing the turn. If you let go of the wheel it sharply snaps back to center immediately, the truck will actually sway back and forth a few times from the force.
2. At slow speed if I make a turn, for example a left turn at 10 mph and hit the gas I can feel at least one of the front tires seem to lock/lose grip and the truck wants to drive straight and just drag the front tires without much turning happening. Basically really bad understeer.
3. High speed front end pulsing, seems like an alignment problem vs rotors but I'm wondering if it's mainly caster again, both wheels fighting to pull the truck depending on which way the road is leaning.
What do you guys think?
post #1099 of 1304 (permalink) Old 05-08-2019, 12:15 AM
KC
Member - AKA Neptune
KC's Avatar
Thoughts on running a RTT with the Dep Hep Drop-in Rack? Anyone think it may be better long term to save up for a gobi rack? Curious to hear anyone's experiences.
KC is offline
post #1100 of 1304 (permalink) Old 05-08-2019, 01:29 PM
2015 Lava Red ❌terra S
duxsterra's Avatar
Basically an unnecessary use of the DH rack because it's just added weight underneath the tent that you can't use anymore. That being said, I will likely do the same thing until I get a front runner rack or I can convince Rocky Mtn Racks to use me as a guinea pig for their racks.
duxsterra is offline
