Review: RockyMtnX Front Winch Mount/Front Sliders/Maxterra Rear Bumper - Second Generation Nissan Xterra Forums (2005+)
post #1 of 10 (permalink) Old 08-11-2012, 02:38 AM Thread Starter
2012 Xterra PRO 4X
Early spring I contacted Steve at RockyMtnX about fabricating a factory bumper winch mount,a set of sliders and threw out the question if he could fab a rear bumper also. The winch mount and sliders were a go and he thought he might be able to get his hands on a used Maxterra rear bumper from a fellow Xterra owner. He gave me a build date of end of June. In the mean time he did acquire the used Maxterra bumper so everything was set in motion -now I'm getting Xterra mod fever.
End of June 3 crates arrived in Anchorage, Alaska - I was out in the bush working so the DW went in and picked them up. When I returned I found 3 heavily created fork-lift friendly crates that you could of used to shore up your truck while you're changing a flat -I'm impressed already. I opened up all to inspect for any shipping damage - I found the winch mount/sliders/bumper secured inside the crates with wood/carpeting bubble wrap - all were in perfect shape! The quality of workmanship is Awesome. I took the rear bumper in to the powder coaters and matched up the Xterra silver will take a week.
I installed the sliders first - not one hitch - they bolted up perfectly and look great. Next was the front winch mount bumper install - with the help of the how-to-posts for grill and bumper removal it went fast again without a hitch. Fit perfectly with no mods, think the elongated holes helped out with the bolt on to frame; you have to take a second look to even notice its there. The hardest part of that install was making the first cut in the plastic bumper. I was able to use the black plastic bumper after it was cut to fit as a template for the silver lower fascia and with a more detailed cut - made it into a nice finish piece. I used a piece of lead solder to make a template of the curve of the grill above the winch to cut the license plate holder to fit like it did on the lower fascia. I installed the winch control box under the hood on top of the fuse box. Got the rear bumper back from the powder coaters and installed in less than an hour - took me longer to install the 7 pin wiring harness. I used brass bushings and washers along with a rubber O ring on the recovery shackles to keep them from flopping around on the front and Maxterra rear bumper. For the license plate light I went to Wally world and picked up a 10" Led flex light - cut it to length and blocked off LEDs until I was satisfied with the amount of light on the plate, it attaches with 3M tape under the license plate gutter.
All in All (Very impressed with the quality of workmanship and detail
that went into the winch mount and sliders and shipping crates) RockyMtnX cleaned up the used Maxterra rear bumper and kudos to the excellent workmanship and customer service!
Front:
https://picasaweb.google.com/1101812...ontWinchMount1
Slider:
https://picasaweb.google.com/1101812...ckyMtnXSliders
Rear bumper:
https://picasaweb.google.com/1101812...erraRearBumper
Last edited by Old Navy; 08-11-2012 at 08:59 PM. Reason: Pictures Not Showing Up ~ So I Picked One of Each
AKXTERRA is offline
post #2 of 10 (permalink) Old 08-11-2012, 02:48 PM
2012 Ebony Xterra Pro-4X
Rescue119's Avatar
looks nice, I am going to eventually make my own but same concepts
Is that an led strip for the license plate light?
Rescue119 is offline
post #3 of 10 (permalink) Old 08-11-2012, 04:17 PM
2011 Xterra Pro-4X
LI11X's Avatar
Looks great.
LI11X is offline
post #4 of 10 (permalink) Old 08-11-2012, 04:36 PM Thread Starter
2012 Xterra PRO 4X
Yes, It was a 10" Flex Light cut down to size and attached with 3M tape that comes with the LED - got it at Wally World, comes in white or blue with 10' of wire, had to cover up LEDS until the brightness was correct
AKXTERRA is offline
post #5 of 10 (permalink) Old 08-11-2012, 09:02 PM
Administrator
2006 Silver Lightning ❌terra "S" 4x4
Old Navy's Avatar
Tweaked OP a little.
"D'Garv"
Member #272
Stock Silver Lightning AT
Live Free. Drink Good Beer. Eat More Sushi.
Old Navy is offline
post #6 of 10 (permalink) Old 08-12-2012, 02:50 AM
2008 Knight Armor Xterra X
shimi1st's Avatar
I like the step
& My Cross Country Dirt Road Trip "
" for
How-to:
shimi1st is offline
post #7 of 10 (permalink) Old 08-12-2012, 10:17 AM
2010 Xterra S
SnowB0und's Avatar
Send a message via AIM to SnowB0und
Nice choice for the rear bumper!
I need to cut my front silver piece out, how did you mount it?
SnowB0und is offline
post #8 of 10 (permalink) Old 08-12-2012, 03:20 PM Thread Starter
2012 Xterra PRO 4X
The silver fascia is attached to the plastic bumper under the shackles with 2 plastic Ford pins I had from a previous job, the bottom is attached with the original bolts to the black plastic bumper. If you look at the front pic (inside the right shackle you can see one of the pins)
AKXTERRA is offline
post #9 of 10 (permalink) Old 03-18-2013, 01:40 PM
Banned
Do you have the number to RockyMtnX
RIDER is offline
post #10 of 10 (permalink) Old 03-18-2013, 11:03 PM
shimi1st's Avatar
PM Him for his info, his number won't be posted on a public forum.
" for
How-to:
shimi1st is offline
