Tire Size Calculator - Page 2 - Second Generation Nissan Xterra Forums (2005+)
post #11 of 16 (permalink) Old 06-09-2015, 07:29 PM
Can you hear it rubbing at full lock?
I wonder if the previous owner had different wheels on and swapped them back out for the stock wheels before they sold it. I can't see what is causing the issue in these pics.
post #12 of 16 (permalink) Old 09-07-2015, 04:00 PM
2014 Night Armor Xterra "S" 4x4
Xwoody14's Avatar
So my question is: If I go from a 265/70 to a 285/75, would I need to replace my differential gears? The size difference doesn't seem drastic enough to warrant a ratio change, but I could be wrong.
Xwoody14 is offline
post #13 of 16 (permalink) Old 09-07-2015, 04:47 PM
2012 Night Armor Xterra Pro-4X
NoahSki's Avatar
Nope.
NoahSki is offline
post #14 of 16 (permalink) Old 09-07-2015, 04:53 PM
Xwoody14's Avatar
Originally Posted by NoahSki View Post
Nope.
What about 305's? Those look sexy as hell, but are quite a step up
Xwoody14 is offline
post #15 of 16 (permalink) Old 09-07-2015, 06:55 PM
NoahSki's Avatar
Depends on what you want to do. Some run 315/75 with stock gears. It's iffy if you want to do rock crawling or other tough off roading I'd advise against it.
Anything over 33" though is going to require fender modification.
NoahSki is offline
post #16 of 16 (permalink) Old 09-08-2015, 08:37 AM
Xwoody14's Avatar
I'm going to be doing a lot of off roading and rock crawling with it. I'll stick with the 285 for now.
Xwoody14 is offline
