Rim Options - Page 34 - Second Generation Nissan Xterra Forums (2005+)
 97Likes
post #331 of 350 (permalink) Old 02-03-2018, 09:40 PM
2015 Xterra
Looking into Fuel Vector rims 16x8 +15 offset with 265/75R16 tires. would I be able to fit this by just using the melt mod. My X is bone stock just looking for a new look
NormSki is offline
post #332 of 350 (permalink) Old 02-04-2018, 11:08 AM
Yes. Stock offset is +30mm, so that means this wheel will only stick out 15mm (about 0.6 inches). You can run a 1.5" spacer with that size tire and fit with just melt mod, so your combo should fit fine.
Trip Photos Page -
"Mods first - life later."
post #333 of 350 (permalink) Old 02-16-2018, 07:30 PM
2015 Xterra
Is there anyway rim/tire size in can run without spacers
NormSki is offline
post #334 of 350 (permalink) Old 04-12-2018, 11:29 PM
2011 Avalanche White ❌terra Pro-4X
AdventureRider81's Avatar
Couldn't find this info on this thread. So, I thought I would add it to help a few folks out there concerned about the limited options.
Bolt patterns on some wheels can be changed. Wheel repair shops (like Jason's Wheel Shop (JWS) in Chino CA) have the equipment to plug the existing lug holes and redrill to the lug pattern you need. Cost varies depending on the shop. I think it is about $30-35 a wheel but my old ass brain is having a memory lapse.
Sorry I don't have pix, but, any decent sized city should have a wheel shop close by, you can google to get info. We were able to get Jeep bolt pattern 5x5.5 re-drilled to a 6x4.5 to fit an Xterra. Since we were able to order the offset and backspace we wanted to. The wheels fit great with no spacers or adapters. The wheel will not lose any integrity so long as it's a quality wheel. The wheel shop will let you know what to look for. The wheels we modded were XD's.
JeffInDFW likes this.
AdventureRider81 is offline
post #335 of 350 (permalink) Old 05-08-2018, 10:53 PM
Banned
2012 Knight Armor Xterra Pro-4X 6MT
This is partially right, since the width of both wheels is different the new wheel will stick out more than just the difference in offset. A 16x8 15mm offset wheel will stick out 28mm more than a 16x7 30mm offset wheel.
knightrider is offline
post #336 of 350 (permalink) Old 06-01-2018, 03:11 AM
Banned
1. Brand: KMC XD Series
2. Model: Addict 2
3. Size: 17x9
4. Backspacing: +18 offset
5. Did you need a spacer? No spacers needed, clears caliper but just barely.
6. Where did you purchase the wheels? Wheelpros
7. Price per wheel? $216
8. Photo:
SHIFT_X, X4dblduty and LVX like this.
post #337 of 350 (permalink) Old 07-10-2018, 10:24 PM
2005 Night Armor Xterra SE 4x4 5AT
Vizard's Avatar
1. Brand: Pro Comp
2. Model: 89
3. Size: 17x8 -12 offset
4. Backspacing: N/A
5. Did you need a spacer? If so, what model? Where did you buy it? Nope. You need the melt mod and some minor trimming
6. Where did you purchase the wheels? Custom Wheel Offset
7. Price per wheel? $141
8. Photo:
Vizard is offline
post #338 of 350 (permalink) Old 07-17-2018, 10:45 PM
2011 Super Black Xterra X
Sznurek's Avatar
1. Brand: Mayhem
2. Model: Warrior
3. Size: 17x9 18mm offset
4. Backspacing: N/A
5. Did you need a spacer? No. You need to do the melt mod with a heat gun. Push the liner back a bit.
6. Where did you purchase the wheels? At a shop.
7. Price per wheel: Too much :P Especially in Canada.
8- Tires: Nitto Ridge Grappler 285/75/17
9: 2" lift overall. Rear- new 500lb springs Front- Bilstein 5100 strut kit.
Sznurek is offline
post #339 of 350 (permalink) Old 10-06-2018, 06:28 PM
2005 Silver Lightning Xterra SE
Adventure_X's Avatar
1. Brand: Level 8
2. Model: Mk6
3. Size: 16"
4. Backspacing:
No spacer needed light rubbing in back of tire
Discount tire
7. Price per wheel?
$125
8. Photo:
LVX likes this.
Adventure_X is offline
post #340 of 350 (permalink) Old 10-10-2018, 12:02 PM
Always loved those wheels. What size tire did you run? Stock suspension?
Syrus5o is offline
