Best Tool for Airing Down? - Second Generation Nissan Xterra Forums (2005+)
 20Likes
post #1 of 44 (permalink) Old 06-05-2019, 11:47 AM Thread Starter
2006 Granite Xterra Off Road
X4dblduty's Avatar
Got frustrated searching, any comments on current tools for quick and monitored air down, meaning ability to set desired pressure? Thanks!
X4dblduty is offline
post #2 of 44 (permalink) Old 06-05-2019, 12:03 PM
ARB Tire Deflator.
https://www.4wheelparts.com/p/arb-e-...a-668137088306
BillySpivitz and kolsky like this.
IM1RU is offline
post #3 of 44 (permalink) Old 06-05-2019, 12:06 PM
2005 Avalanche White Xterra SE
fletch350z's Avatar
I personally use these (just because they're much more cost effective and still work well).
https://amzn.to/2MudUfp
fletch350z is offline
post #4 of 44 (permalink) Old 06-05-2019, 12:16 PM
2005 Night Armor Xterra SE 4x4 5AT
Vizard's Avatar
I've been using this one, so far i like it, airs down fast
Vizard is offline
post #5 of 44 (permalink) Old 06-05-2019, 12:41 PM
545
2005 Xterra
I use the staun version of this. They are the original, but kinda expensive for something that isnt critical
fletch350z likes this.
545 is offline
post #6 of 44 (permalink) Old 06-05-2019, 12:57 PM
GeolJon's Avatar
Originally Posted by IM1RU View Post
ARB Tire Deflator.
I second this. Fast and seems pretty indestructible. A bit of a learning curve, so be sure to practice using it before hitting the trail.
GeolJon is offline
post #7 of 44 (permalink) Old 06-05-2019, 01:12 PM
Oddly I have the Smitty Built one currently, because I've had two of the ARB's stolen from my truck. They are the same, but I like the ARB storage bag way better.
IM1RU is offline
post #8 of 44 (permalink) Old 06-05-2019, 01:19 PM
ChrisHaynesUSA's Avatar
I prefer the Staun Deflators.
set them, lock ring, done.
screw on and wait till air stops escaping.
the gauge type requires you to monitor constantly .
YMMV
kryter and Jayrat like this.
ChrisHaynesUSA is offline
post #9 of 44 (permalink) Old 06-05-2019, 01:28 PM
YMMV
And yet I'm still done before you guys with the Stauns
I can also vary my aired down PSI depending on the terrain, just by reading that handy little gauge.
I know guys who use that little nub on the back of their pressure gauge.
Point is, they all work. To each their own, there really isn't a wrong answer here.
IM1RU is offline
post #10 of 44 (permalink) Old 06-05-2019, 01:33 PM
Super Moderator
Mr. Bills's Avatar
I have used many different tire deflators over the years.
An inexpensive option that always works, has no moving parts, and costs very little is this one from Teraflex, usually about $15. I have carried one for more than 25 years, now as my back-up:
Claimed to be the fastest are the ARB and Currie units that remove the valve core, but you still have to bend over and fiddle with the pressure on each tire, $38-40. [I do not recommend the S*ittybilt and other cheap Chinese knockoffs - sure they cost less but you get what you pay for.]
The most convenient are the automatic tire deflators such as Staun and the improved version sold by Harry Llewellyn at Coyote Enterprises - $56-72 depending upon the model and where you buy them, less for the Chinese knockoffs. Harry was the face for Staun in the U.S. until the Australian company went broke in 2009 and Harry still has a working relationship with the original patent holder in Australia. However, his Coyote Automatic Deflators have several improvements evidenced by a new patent held by Harry and are a step up from the Staun and Staun II deflators. Coyote Automatic Deflators are far superior to the cheap Chinese knockoffs such as the EZdeflators referenced in Post #3 and the deflators sold with the S*ittybilt brand. [I have a set of the EZdeflators and find them difficult to set. They also produce inconsistent results which makes them no bargain.)
Staun
Coyote
https://www.coyoteents.com/deflators/
Shown below are my Coyote Automatic Deflators. They came pre-set at 12 psi but you can have them set to any pressure you desire and they are easy to re-calibrate when you want to change pressures. The advertised range is 4-56 psi.
Unlike the knockoffs, Coyote Automatic Deflators always deflate to exactly the same pressure, never stick open or bleed air, and you can put them on and drive while your tires deflate unlike the other brands. I can air down all four of my 35" tires from 28 psi street pressure to 12 psi trail pressure in about 4 minutes which compares favorably just over one minute per tire with the ARB deflator and I don't have to bend over to manually set the final pressure as with the ARB product. I think they are a good buy at $56 ($60 if Harry sets your custom pressure) and well worth the price difference over the imitations.
X4dblduty and NWCoffeeGuy like this.
Mr. Bills is offline
