Brake Fluid Spitting out by Spare Tire - Second Generation Nissan Xterra Forums (2005+)
  • 2 Post By 545
post #1 of 9 (permalink) Old 05-17-2019, 01:45 PM Thread Starter
2006 Granite Xterra SE
Hi everyone,
Needing some help. I just changed out my driver side Hub assembly, driver side break caliper and all front brake pads and rotors on my 2006 Xterra SE. When I go to bleed the break system using the two man method, and using a piece of 2x4 to make sure the brake is not hitting the floor. I get the breaks hard when the car is off, the minuet I turn it on the break hits the floor and I hear a air flow sucking hissing noise. Also I found my brake fluid reservoir won't stay full. I found a rubber tab on the rear break line next to my spare tire that is shooting out break fluid on to the spare. I feel this is multiple issues. from what I can find online, is the master cylinder may be bad, but I can not find anything about that rubber tab on the rear brake line. any and all help is welcome and needed.
thanks
Fox
Rogue Fox is offline
post #2 of 9 (permalink) Old 05-17-2019, 02:18 PM
2012 Night Armor Xterra S 4x4
BlackbirdSR71's Avatar
Put up a photo of that leak ?
RJ Giddings
BlackbirdSR71 is offline
post #3 of 9 (permalink) Old 05-17-2019, 03:38 PM
Here's an image I threw together of the rear end with brake lines in the red boxes so we can pinpoint this better. Are you talking about the connection in the A box?
post #4 of 9 (permalink) Old 05-17-2019, 07:22 PM
545
2005 Xterra
Box A is the cable connection for the parking brake. No brake fluid
The two rubber lines going up from box B are the brake lines; the connect to the hard lines at a bracket there. I suspect it will be leaking from a fitting. Pull the spare down and check it out when someone is pushing on the brakes. It will be obvious.
545 is offline
post #5 of 9 (permalink) Old 05-17-2019, 09:32 PM
Start with fixing the leak. I bet it’s not a bad mc, just the leak.
Once you get the leak fixed, before you bleed at the calipers, bleed at the abs pump. Crack the two lines feeding the abs from the mc then push the pedal, then tighten the line, lift the pedal and repeat (don’t pump it up first like you do at the caliper). After you do those two, do the 4 going out of the pump to the calipers next. Same method. After that, bleed at the calipers like normal.
Put a bunch of rags under the abs pump, it makes a mess. Might want to have some denatured alcohol to clean up the spilled brake fluid too.
Good luck.
post #6 of 9 (permalink) Old 05-18-2019, 09:52 AM Thread Starter
First,
Thanks everyone for the quick replies. So using the photo Genral_Tarfun put together, I made box C. the rubber tab on the left is were the fluid is spitting out of when you pump the brakes. the back side of the spare tire is covered with fluid. I plan on getting under there today to take a video and pics. As 545 pointed out it looks like the line coming from Box B.
post #7 of 9 (permalink) Old 05-18-2019, 10:26 AM
That’s good. That hard line is really cheap from the dealer. I think it was less than $10 when I replaced mine.
post #8 of 9 (permalink) Old 05-18-2019, 12:53 PM
545
2005 Xterra
Those rubber “tabs” are just to hold the line from rubbing. Bend them out of the way, it’s just a brake hardline that goes the length of the axle. You can bend one to match from the auto parts store if you need to get back on the road, but if you aren’t familiar with flaring brake lines, and have the time, just order the part from the dealer. Make sure you use a brake line wrench in the fittings- a flare wrench
ZheKing and PebblePimp like this.
545 is offline
post #9 of 9 (permalink) Old 05-23-2019, 07:21 AM
545
2005 Xterra
How did you do OP?
545 is offline
35s and the Skinny Tire coloradoman Brakes, Tires and Wheels 13 05-10-2019 11:11 AM
Schedule of Events | 2019 Discount Tire Rally on the Rocks Discount Tire Discount Tire 0 05-08-2019 05:35 PM
DOT 3 vs. DOT 4 brake fluid (AT) COBigRobb Brakes, Tires and Wheels 6 07-18-2012 02:47 PM
Anyone have spare tire ideas?? ptlm15125 Brakes, Tires and Wheels 8 02-22-2007 03:30 PM
