Unbalanced Braking - Second Generation Nissan Xterra Forums (2005+)
  • 1 Post By jsexton
  • 1 Post By JadAl
  • 2 Post By JadAl
post #1 of 10 (permalink) Old 05-07-2019, 04:02 PM Thread Starter
2013 Brilliant Silver Xterra Off Road
JadAl's Avatar
Unbalanced Braking
Hi Guys,
I am experiencing an uneven/unbalanced braking when hitting the brakes hardly at higher speeds.
The truck swerve right on a hard brake, and the ABS kicks in for few moments.
Any experience in similar cases? How to approach this?
Thnx
Jad.
Keep revving
JadAl is offline
post #2 of 10 (permalink) Old 05-07-2019, 04:22 PM
Don
2015 Xterra
Your brakes (likely front) need attention. You have symptoms of brake issues but with out examining them, guessing the cause is somewhat futile and pointless.
Don is offline
post #3 of 10 (permalink) Old 05-07-2019, 04:34 PM
2011 Night Armor ❌terra New Hotness (Pro 4X)
Ripper's Avatar
Stuck caliper piston, or slide pin most likely
Ripper is offline
post #4 of 10 (permalink) Old 05-07-2019, 05:26 PM
My ‘06 did that with air in the lines after a front caliper replacement and hasty bleed.
Bled all 4 again properly and problem solved.
MartinX is offline
post #5 of 10 (permalink) Old 05-07-2019, 11:53 PM
I've had pull before from an incorrect toe angle and stuck slide pins but never to the point of activating the abs, that sounds like it's locking and the abs is having to release the wheel.
post #6 of 10 (permalink) Old 05-07-2019, 11:56 PM
meanGREENnugget's Avatar
Besides brakes it could be alignment, or uneven tire wear.
meanGREENnugget is offline
post #7 of 10 (permalink) Old 05-08-2019, 06:55 AM
You might have a few things going on.
Stuck guide pin and/or caliper piston can make it pull.
ABS makes me suspect if the front wheel bearings too.
Worn out lca bushings will make it pull weird on heavy braking too, especially if they are only bad on one side. This could also explain the abs as the alignment would change significantly during braking.
General_Tarfun likes this.
post #8 of 10 (permalink) Old 05-08-2019, 02:06 PM Thread Starter
JadAl's Avatar
Thank you guys,
Actually i bled some of the fluid from the front brakes (wanted to check if fluid is reaching the caliber as well). I felt a bit of improvement last night.
Today morning the truck was back to normal. I felt it directly on the first brake that the braking system is balance again.
So most likely there was air in the system it seems. Before i started it today morning, I gave it nice few pumps on the brakes with the engine off. Not sure if that helped.
Seems truck heal over night
MartinX likes this.
Keep revving
JadAl is offline
post #9 of 10 (permalink) Old 05-14-2019, 02:50 PM Thread Starter
JadAl's Avatar
UPDATE:
Keep revving
JadAl is offline
post #10 of 10 (permalink) Old 05-14-2019, 02:54 PM Thread Starter
JadAl's Avatar
UPDATE:
The unbalanced braking reappeared after a full brake system bleed, which suggested a bad master cylinder. As it is known, the cylinder feeds pressurized fluid to 2 independent hydraulic loops (for safety purpose). Seems one of the loop was getting bust and not enough pressure build up ( i think in the X the loops are diagonal, front right and rear left brakes on the same loop). Hence the swerve when braking.
Changed the cylinder, performed the required bleeding and everything was back to normal. The brake paddle got harder feel to it now, and won't go all the way (as before).
jsexton and General_Tarfun like this.
Keep revving
JadAl is offline
Does your ABS Kick-in when Braking Hard? trollhattan Brakes, Tires and Wheels 19 10-13-2018 05:28 PM
headlights dim when braking surfnobc2 Electrical 5 02-18-2012 08:05 PM
Downshift while braking downhill? COBigRobb Powertrain & Driveline 5 03-28-2011 09:16 AM
Grinding noise when braking shocca Brakes, Tires and Wheels 6 11-22-2010 05:06 PM
Braking and vibration problem. leung19 Powertrain & Driveline 12 09-15-2010 12:56 AM
