NissTec Brake Upgrade Kit - Page 3 - Second Generation Nissan Xterra Forums (2005+)
 18Likes
post #21 of 25 (permalink) Old 05-10-2019, 01:26 PM
2007 Super Black Xterra S Titan Swapped!
GPD605X's Avatar
Originally Posted by JOSX2 View Post
normally...yes.
For our rigs...no. The bleeding order @AdventureRider81 listed is the proper order per FSM
Well that explains why my brakes were squishy until i vacuum bled them lol
Originally Posted by T-REXterra View Post
"100% of people with snorkels have bigger wieners than those without snorkels."
-Abraham Lincoln
GPD605X is offline
post #22 of 25 (permalink) Old 05-10-2019, 01:29 PM
Caretaker of The Minion
JOSX2's Avatar
actually....correction to that pattern....
1. Passenger Rear
2. Driver Front
3. Driver Rear
4. Passenger front
on Instagram
(North Carolina Xterra Club)
JOSX2 is offline
post #23 of 25 (permalink) Old 05-10-2019, 02:08 PM
2011 Avalanche White ❌terra Pro-4X
AdventureRider81's Avatar
1. Passenger Rear
2. Driver Front
3. Driver Rear
4. Passenger front
Attachment 111592
Thanks for looking up the actual specs.
The driver front that soon throws my common sense mind right out the window. I use to always doing that one last.
Good info here. And hope this thread can help those with the squishy brake syndrome. It for sure helped my truck. I no longer can press brake to the floor like before. Pedal engages much higher now. And I didn't even do it in the correct order.
Build Thread
(StormTrooper Gretchen (big,white,fat,ugly,and German): 2015 BMW R1200GS Adventure White
AdventureRider81 is offline
post #24 of 25 (permalink) Old 05-11-2019, 10:48 AM
2011 Xterra Pro-4x
I can confirm leaving the engine running makes a difference.
I had a really soft brake pedal that would keep going down as I applied the brakes. I did a brake bleed in the in the proper order with ABS disconnected. No change. The next day I read this thread and did the bleed again with the engine running and the ABS still connected. It is much better now.
IM1RU and AdventureRider81 like this.
beaterpc2 is offline
post #25 of 25 (permalink) Old 05-11-2019, 06:33 PM Thread Starter
Desert Explorer
2015 Brilliant Silver ❌terra Pro-4X
nworker's Avatar
Originally Posted by MeHere! View Post
Ordered mine today, plus new rotors
What are other's thoughts on these front pads?
Hank
N6HWW
nworker is offline
FS: NissTec Extended U-Bolt Kit Stephen_Konrad For Sale 1 03-04-2016 09:40 PM
NissTec Ultimate vs Extended Lift Kit vdgraaf Suspension & Steering 20 11-04-2015 04:52 PM
FS FEELER: NissTec Ultimate Kit Coilovers JackAttack13 For Sale 20 04-26-2014 11:41 PM
