Tire Size and Ideal PSI for Road Driving - Second Generation Nissan Xterra Forums (2005+)
  • 1 Post By LBX
  • 1 Post By Longboardr
  • 1 Post By AlbatrossCafe
post #1 of 6 (permalink) Old 03-03-2019, 12:15 AM Thread Starter
2013 Xterra Pro-4X
I just got my 2013 pro4x a couple weeks ago I have BFG all terrains LT275/70R17 on it anyone know what the best psi i should be riding them on for the on road driving?
WolfVsRam is offline
post #2 of 6 (permalink) Old 03-03-2019, 12:52 AM
LBX
LBX's Avatar
Look at the sticker on the door sill, it will have the manufacturer recommended psi. Mine is 35 psi; 2011 Pro-4x with 265/75/16 tires. When I had the stock BFG Rugged Trails I ran them at 35 psi. That being said, when I had BFG KO2’s I ran them at 40 psi. And my new Falken Wildpeak ATW3 are inflated to 38 psi (which is what America’s Tire recommended)
WolfVsRam likes this.
LBX is offline
post #3 of 6 (permalink) Old 03-03-2019, 08:01 AM
post #4 of 6 (permalink) Old 03-04-2019, 01:10 PM
Tire width, height, load range, truck weight, and a few other factors help determine your PSI.
E.g. I run my 315/75/R16 tires at ~30 PSI road. My 285/75/R16 winter tires I run at 37 PSI. In order to really figure out the correct pressure, you need to do the chalk test like @Longboardr mentioned above.
OR you could just run them at ~36-37 PSI which is stock and you will probably be good enough
Trip Photos Page -
"Mods first - life later."
post #5 of 6 (permalink) Old 03-05-2019, 01:03 AM Thread Starter
2013 Xterra Pro-4X
Thanks all I am new to the bigger tires didn't know if I should follow what the door says or not.
post #6 of 6 (permalink) Old 04-19-2019, 03:03 PM
2010 Xterra OR 6MT
The factory 35 is a good starting point. Lots of different size tires used across the Nissan truck line and they all have the same 35 PSI recommended pressure.
The chalk test is good for setting a baseline on a race car, but I have seen it flawed for the street. Usually too low.
early 2010 is offline
Wheel and Tire Size wiseguy3501 Brakes, Tires and Wheels 8 03-11-2013 04:11 PM
Gearing and Tire Size HiThisIsPaul Powertrain & Driveline 16 02-01-2013 09:33 PM
