295/75/16 or 285/75/16 Tire Size Options - Page 2 - Second Generation Nissan Xterra Forums (2005+)
post #11 of 18 (permalink) Old 02-15-2019, 12:31 PM
ChrisHaynesUSA's Avatar
Can you please re-tittle your thread header to something like:
Tire question on 295 versus 285 / 75 /16 Tires
or
Tire question on 295 versus 285 wheel well contact.
this will help the next guy who searches the website.
ChrisHaynesUSA is offline
post #12 of 18 (permalink) Old 02-15-2019, 01:18 PM
Originally Posted by outback97 View Post
The 295 is a less common size... total wild guess here but you'd have to walk past nine members on this site with 285/75's to find one with 295/75's.
Quoting myself here, I had to satisfy my curiosity about this because it's a slow day and I like numbers. My very non scientific way was to look at the past ~3 years of posts on the tire options thread and note the tire size of the past 50 responses.
https://www.thenewx.org/forum/69-bra...e-options.html
Out of the past 50 tires listed, the section widths broke down as:
255 - 1 or 2% (255/85/16)
265 - 21 or 42% (mostly 265/75, some 265/70)
275 - 1 or 2% (rare size here, this was from Qatar)
285 - 21 or 42% (mostly 285/75/16, a few 285/70/17)
295 - 2 or 4% (one 295/75/16, one 295/70/17)
315 - 4 or 8% (three 315/75/16 and one 315/70/18)
So my WAG of one out of ten 295's : 285's was pretty close.
or
@Marco X please do this. I was going to suggest this as well. Informative thread titles go a long ways towards eliminating confusion when people bother to search, as the OP did.
post #13 of 18 (permalink) Old 02-15-2019, 03:40 PM
GeolJon's Avatar
Good ideas and points made here.
Choices in tires for the Xterra are not unlike choices with lifts. It is pretty simple and inexpensive to get around 2" of lift on the Xterra, but if you want to go more than that, it gets significantly more difficult, complicated, and expensive (i.e. you need to be worrying about new coilovers, leaf packs, UCAs, bumpstops, brake lines, titan swap, etc.).
Likewise, it is fairly easy and straightforward (i.e melt mod) to put bigger tires on the Xterra up to a certain point, ~33" or 285/75 typically, but once you go past that, you are going to need to worry about and shell out more money things like tire carriers, new wheels, wheel spacers, lifting, frame rubbing, and regearing.
"It is the natural and legitimate ambition of a properly constituted geologist to see a glacier, witness an eruption, and feel an earthquake." -G.K. Gilbert
GeolJon is offline
post #14 of 18 (permalink) Old 02-28-2019, 08:12 PM Thread Starter
2011 Super Black Xterra X
or
sorry for the long delay, I did change the title of the thread though. I hope this helps some young fella in the future.
Marco X is offline
post #15 of 18 (permalink) Old 02-28-2019, 09:26 PM
2008 Desert Stone Xterra SE 4x4
Nasarno's Avatar
My experience with BFG 285/70R17 on stock SE wheels which is even smaller than 285/75R16:
With 2" - 3" of suspension lift and no body lift, a little melt mod might be needed to clear the front tires' edge when turning, but inner side of rear tires rub the frame and body in full articulation (highest position). I had no extended bump stop and after few trail run, both body and frame's bare metal were exposed.
Since I didn't want to compromise the articulation by extending the bump stop, I added 1.5" wheel spacers. It fixed the rear issue, but front tire were hitting fender's corner even before full steering rotation. So, I trimmed the fender! Situation is a little worse with 285/75R16 and more worse with 295s.
My conclusion after you upgrade to 285s:
Either you no more offroad,
or you add rear bump stop extensions,
or keep painting frame and body where rear tire rubs in full articulation,
or you add wheel spacers;
if you do so, then:
either you add body lift,
or you pay a lot more for more suspension lift,
or you end up trimming your fender!
LOL....
Nasarno is offline
post #16 of 18 (permalink) Old 02-28-2019, 10:29 PM
2006 Xterra SE
if you do so, then:
LOL....
Nominal tire size difference between a 285/75/16 and 285/70/17 is only .1". I wouldn't really call it "smaller" That's like one burnout away.. lol... Also each tire manufacturer has slightly different real dimensions for the same rated size so.. they are effectively the same. One tire maker 17 would be bigger than the others 16 and vice versa.
It's really good to heard your experience about the stock SE 17s, you don't see too much info on them (I'm shopping 33's currently for my SE). Everyone just assumes they are the "same" as 16's fitment. But as you are pointing out.. that isn't true.
The spec on the stock 17s is 7.5Jx17 ET30 and the other model 16s are 7Jx16 ET30 which means that the SE wheel has the same offset, but a wider rim, so you split the .5" diff on both inside and outside. Since the rim is 1/4" closer to the frame you would get more frame rubbing compared to the stock 16 for the same width tire.
IntellectualRedneck is offline
post #17 of 18 (permalink) Old 03-01-2019, 01:15 PM
Nasarno's Avatar
Something has changed over the past couple years about BFG KM2 tire spec. I clearly remember that when I purchased them, 285/70R17 spec was 32.5" diameter, while 285/77R16 was 32.8". It perfectly matched the real world measurement, when I received the tires. And now with less than 8K miles on them, they stand no taller than 32.0" with 40 psi.
Now I searched again and I see different numbers from different web sites, varying from 32.8" to 33.1" for the same 285/70R17 KM2 !!!
It's a common complain that BFGs are on the lower side of the spectrum for the same nominal size. Probably, they retooled their tire manufacturing, or just edited their spec numbers to match the competition! Either way, I cannot prove it anymore by referring to a link on the internet
That might be why I did not hear much about rear tires rubbing the frame. Yes, SE wheels are the widest stock rims.
Nasarno is offline
post #18 of 18 (permalink) Old 03-01-2019, 02:10 PM
2006 Xterra SE
Bfg's also have square blocky profile, i could see how they'd be more likely to rub at full turns
Sent from my SM-G920W8 using Tapatalk
Tire Size Question ? secular Brakes, Tires and Wheels 4 11-09-2017 02:51 PM
CARiD Technical Article: Off-Road Tire Size Measurements Carid CARiD.com 0 08-17-2017 10:25 AM
Tire Size Question ? Steamboat927 Brakes, Tires and Wheels 2 04-23-2015 07:53 PM
FS: Tire Chains fit Stock Tire Size - Sac, CA JsXterra For Sale 0 07-24-2013 02:58 PM
Tire balancing issues with 285/75/16 D.B. Cooper Brakes, Tires and Wheels 10 09-07-2006 03:16 PM
