V-shaped Spring Clip - Second Generation Nissan Xterra Forums (2005+)
  • 1 Post By BillySpivitz
post #1 of 3 (permalink) Old 02-08-2019, 08:01 PM Thread Starter
Just a Hunter's Avatar
For those which have performed a brake job on their Xterras.
In factory form, did your brake calipers have a V shaped spreader spring installed?
If so, were there one spring per side or two
Robert E. Lee
Just a Hunter is online now
post #2 of 3 (permalink) Old 02-08-2019, 10:36 PM
2010 Xterra X 4x4 6MT
BillySpivitz's Avatar
The fronts should have one per side. Mine did not, either they fell off or someone didn't replace them at some point. The Raybestos pads I bought came with replacement shims, retainers, and springs. Some cheaper pads do not come with the hardware.
Just a Hunter likes this.
BillySpivitz is offline
post #3 of 3 (permalink) Old 02-12-2019, 05:20 PM
Sometimes they fall off, they're not super critical but you can buy them separately part of a brake hardware kit. I ran two on each caliper at one point but even then I didn't really notice much of a difference.
How-to: OME Coil-over Assembly and Installation jeff_redx How-to's 13 10-11-2018 01:18 PM
OregonX: Rear Coil Conversion OregonX Xterra Projects 194 04-11-2018 07:52 PM
How-to: Install NissTec Ultimate Lift Kit (Pictures Added) Wasabi How-to's 36 05-18-2016 05:55 AM
Radflo 2.0 Spring Swap mtnbiker49 Suspension & Steering 16 08-05-2015 04:46 PM
Fuel door spring tension clip thingy.... Guit Fiddle Exterior 12 12-07-2007 10:25 PM
