Wheel Spacers Overview: Hub/Lug/Wheel - Centric - Page 7 - Second Generation Nissan Xterra Forums (2005+)
 19Likes
post #61 of 66 (permalink) Old 05-12-2018, 10:39 AM
2005 Super Black Xterra S
TurboChris's Avatar
Just to add to the knowledge base here....I bought these eBay 1.5" Hub Centric spacers about a month ago. Installed them a week ago and have put a couple hundred miles on them at speeds up to 85mph. NO vibrations or anything funny. Money well spent.
https://www.ebay.com/itm/4pc-38mm-1-...72.m2749.l2649
TurboChris is offline
post #62 of 66 (permalink) Old 11-06-2018, 09:10 AM
TNX Realm Noobie - AKA Grog
2008 Xterra X
Grog the Canuck's Avatar
Question The brand name?
Originally Posted by 1xterra1 View Post
Wow, this is a lot of information and I feel I have info overload. I purchased new wheels 16x8 6x4 114.3 with a +25mm offset. The retailer swore they would fit well... they don't. The calipers are in the way! So my question is, would a 1 inch spacer work? or do I need a 1.5 inch spacer? I have a 2010 S or SE or X (Not sure)
I was considering a similar rim to accomodate a slightly wider tire that stock but your post has me thinking. Can you tell me what brand or make and model the rims you bought are?
Grog the Canuck
Grog. In Canada
Grog the Canuck is offline
post #63 of 66 (permalink) Old 11-06-2018, 11:31 AM
2008 Xterra X
It's fascinating that so many young and enthusiastic owners are equipping their Xterras with spacers ranging from 1.5" to 3" - despite the fact that many who have them (and negative offset rims) are facing a variety of problems that started within a day, a week or a year of installing them. There are marketers and committed users who insist that spacer problems are all related to moronic installation by owners who aren't mechanically inclined. Some perhaps, but I have met more than a few competent backyard mechanics who own a variety of offroad and overland trucks and have faced similar or worse issues than those described in this forum. There is a raft of scientific information in SAE journals and European driving publications that explains the intricacies of steering and suspension geometry and the specific troubles that will eventually befall a machine when these systems are pushed beyond design parameters. It's all there in black and white for those motivated enough to do their own objective research.
I could write on this at length but I'd probably be banned for boring Xterrans into seizures yet each time I visit its a bit like deja vu all over again - you know the ending, it's something expensive and disheartening that no one wants to hear about. I am an ancient who's, perhaps, a bit too bothered by physics and math for this topic but it was my forty year old son who told me that "this is a era of incredible hype and instant gratification" and, while that may not be true, there certainly is an obsession with big spacers on many vehicle forums.
There are huge bucks to be made in bits of shiny billet these days and short-term gains in pleasure are still outrunning long-term pains to wallets... at least until the bills start coming due. So choose, but choose wisely,
Grog the Canuck
Last edited by Grog the Canuck; 11-06-2018 at 11:43 AM. Reason: speilling mustakes
post #64 of 66 (permalink) Old 02-14-2019, 05:50 PM
2006 Granite Xterra Off Road
X4dblduty's Avatar
ARP Studs
OK, I checked this entire sticky hoping to find some answers, really to address my MILD plan to use 1" spacers only, not wider. I need this for more stability at articulation moments (any little bit helps, my thought). I come with some road racing background and have used longer, stronger ARP studs with mild spacers, e.g. 1" or less, to address use of different sets of wheels/tires for tracking vs street. The longer ARPs go through the hub/wheel centric spacers straight to the wheels. This allows for the spacers to have consistent solid material with only the 6 holes drilled for the studs, as opposed to the usual spacers stated above with offset studs.
So, has anyone used this approach for wheeling/crawling? Interested to see if any drawbacks, because again I've used them in race conditions with no issues and address wheel bearings when needed.
X4dblduty is offline
post #65 of 66 (permalink) Old 04-29-2019, 09:24 AM
2011 Silver Lightning Xterra S 2wd 5AT
TeXas-Hooligan's Avatar
If I'm just going to be running the stock 16" wheel and tires that are currently on my 2011 Xterra S then I won't need to do any fender trimming correct?
I actually like the look of the stock wheels but I want to paint them black and have them stick out just a bit more than they currently do so I'm considering adding 1.5" spacers.
TeXas-Hooligan is offline
post #66 of 66 (permalink) Old 04-29-2019, 10:12 AM
Youíll most likely only need to do the melt mod, if that. No cutting until you go up to 285ís with the spacers.
What size tire is on the truck?
Incidentally, Iíve got a set of spacers that Iím not going to use. Bought them from a member here maybe 6 months ago. Went a totally different direction.
He ran them for about 20,000 iirc. If you want them let me know and Iíll PM you more info.
(Iíve also got a brand new mild lift kit if that is something you are looking for.)
P.S. Might have an end cap for that step rail too!
TeXas-Hooligan likes this.
Why doesnít anyone ever ask for the least aggressive mud tire? ~jsexton
MartinX is offline
