Taylor Spaulding's '13 Xterra - Page 2 - Second Generation Nissan Xterra Forums (2005+)
 17Likes
post #11 of 20 (permalink) Old 04-13-2019, 08:55 PM Thread Starter
2013 Night Armor Xterra S
Taylor Spaulding's Avatar
Added the Rough Country spacer and shackle lift kit! All aligned and ready to go. I just received my yearly bonus for work so I will be putting about 1/2 of it into doing a couple of prep mods:
1. Relocating the PS reservoir
2. Plumbing in a heat exchanger off the outlet heater hose
In preparation for a on-board hot shower and dual battery setup.
For the hot shower I have to find a local holding tank, luckily I live right next to a Camping World. And then I'll work on the plumbing. The tank will either be in the under-floor cargo or in the spare tire void!
BigErn likes this.
Taylor Spaulding is offline
post #12 of 20 (permalink) Old 04-21-2019, 04:12 PM Thread Starter
Finished Plumbing the Heat exchanger
Wow...not easy to do in the small space.
I originally had planned on bolting the exchanger to the fuse box, more for stability than anything else (See pics) However, in doing so the angles from the heater and return nipples were too sharp and kinked the hose lines. Currently working on fabricating an angled strap to hold the exchanger in place, but here it is for now!
post #13 of 20 (permalink) Old 04-21-2019, 04:23 PM Thread Starter
Working fabbing up the junction box for my rear hatch switches which will eventually power my Water Pump, OBA, Overhead lights and possibly two or three more items.
The switch panel is from here:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The fuse box is :
https://www.amazon.com/MICTUNING-6-C.../dp/B07FT1Z4MS
Relays are just standard 30/40 amp rated automotive fuses.
I plan on fabbing the junction box out of ABS, glueing the box behind rear passenger panel and then the cover will go on over the top, flush with the rear panel, that way the switches and vent/viewing window is easily accessed, but looks stock.
JEMZ, Nasarno, TerryD and 1 others like this.
post #14 of 20 (permalink) Old 04-23-2019, 01:21 PM
2013 Avalanche White Xterra S 5AT
13ADVX's Avatar
digging the build. in for the hot shower.
13ADVX is offline
post #15 of 20 (permalink) Old 04-27-2019, 05:18 PM Thread Starter
Thanks!! Still on the way!! I've finished fabricating the tank frame and adding the fittings. The plumbing is going to be a bit expensive, so I'm holding off for a bit.
File Type: jpg IMG_20190424_182848_01_1556399789317.jpg (2.33 MB, 16 views)
Nasarno likes this.
post #16 of 20 (permalink) Old 04-27-2019, 05:20 PM Thread Starter
Just finished constructing and wiring up my rear switch panel and fuse/relay box and got it installed! I have not installed the second battery yet (setup is sitting on the floor waiting for my friend who wants to help) but once it is installed i'm planning on running 2 AWG leads to the rear following the OEM wiring bundle.
File Type: jpg MVIMG_20190427_134246_1556400092331.jpg (5.67 MB, 17 views)
Nasarno likes this.
post #17 of 20 (permalink) Old 05-19-2019, 09:04 PM Thread Starter
Installed my dual battery system!!
JEMZ likes this.
post #18 of 20 (permalink) Old 05-26-2019, 05:07 PM
Are those custom brackets for the PC 1200's?
post #19 of 20 (permalink) Old 05-26-2019, 05:49 PM Thread Starter
Yeah, I posted a link in my How-To thread!
PhullD likes this.
post #20 of 20 (permalink) Old 05-26-2019, 06:03 PM Thread Starter
Added the water tank. The cage is bolted through the body in the front and back, and a middle brace will be added to bolt through the frame rail. I can currently hang off the cage without issues, without the middle brace, but I prefer to overbuild my setups.
File Type: jpg MVIMG_20190525_202749_1558908159938.jpg (6.27 MB, 13 views)
