ISO: Rockford Fosgate Amp - Second Generation Nissan Xterra Forums (2005+)
  • 1 Post By KaBoom
post #1 of 10 (permalink) Old 06-04-2019, 09:16 PM Thread Starter
2012 Xterra Pro-4X
I just purchased a 2012 Pro-4X and I love it, except for the alternator whine Iím getting through the sound system. Iíve spent a lot or time trying to troubleshoot and I think Iíve determined itís due to a faulty amp. The original owner had replaced the Rockford Fosgate amp with a re-built Clarion amp, which i think is causing my issues. Anyways before I buy one off eBay I figured Iíd check on here to see if anyone has one they would be interested in selling? Thanks for the help.
msimons72 is offline
post #2 of 10 (permalink) Old 06-04-2019, 10:10 PM
oji
What makes you think the amp is faulty?
oji is offline
post #3 of 10 (permalink) Old 06-06-2019, 03:14 PM
Wasn't the RF system some kind of oddball ohms?
post #4 of 10 (permalink) Old 06-06-2019, 11:35 PM
I'd start by inspecting whatever the previous owner did with that amp install. Is the original harness still even intact or did he cut it off?
post #5 of 10 (permalink) Old 06-09-2019, 10:13 PM Thread Starter
2012 Xterra Pro-4X
The only way I can get the alternator whine to stop is by either disconnecting the power to the amp or the amp output harness. I've checked all the fuses, tried taking out the head unit, taking off the antenna, and checked the ground on the power harness to the amp. I also tried disconnecting the subwoofer but that didn't help either. It's heard through all the front speakers. I've cleaned the negative terminals and check to make sure everything is tight. It only happens while the engine is running and it's very inconsistent. Sometimes it starts as soon as I start the truck and other times it'll take 30 min.
I know the previous owner had someone replace the amp (it also says remanufactured 2011 and is a Clarion brand not Rockford. He wasn't too. Sure what exactly had been done to it but said the whine has been present for a long time but since he almost never drove the truck it didn't bother him (it was a 3rd vehicle for him...he only put 18,750 miles on it since 2012).
I'm open to any other ideas...
post #6 of 10 (permalink) Old 06-09-2019, 10:15 PM Thread Starter
2012 Xterra Pro-4X
It's still the stock harness (it's all intact) and the remanufactured amp does say Nissan on it but it's a Clarion amp so I'm wondering if it's not the right amp for the rest of the system. I've check the grounds and they seem fine.
post #7 of 10 (permalink) Old 06-10-2019, 12:13 AM
2009 Avalanche White Xterra Off Road
KaBoom's Avatar
Crutchfield has a good resource for this. They also have a link to a diagnostic flowchart on the page. In my experience, it is usually the ground.
SledheadX likes this.
KaBoom is offline
post #8 of 10 (permalink) Old 06-10-2019, 11:18 AM
oji
It shouldnít matter what kind of amp you are using as long as your amp is installed properly. Iíd start with finding out how much power your amp is putting out. Not the peak but constant rms. That will determine if your using the correct wires that are powering your amp. Your ground has to be a sufficient gauge to match your power wire. Also, are theyíre crossovers installed? Everything else is grounded correctly?
oji is offline
post #9 of 10 (permalink) Old 06-10-2019, 06:14 PM Thread Starter
2012 Xterra Pro-4X
Thanks for the ideas. It's all the factory wiring and harnesses. I can't find anything else that was modified. I've tried taking the amp out of the bracket completely and placing it on carpet and even wrapping it in foil to try to further isolate it from a common ground and nothing seems to really help. Everything else seems to be grounded correctly (I did find a damaged ground on the bluetooth harness that I repaired and got that working again). I used the Crutchfield diagnostic flowchart and it kept bringing me back to damaged amp. Rather than having to rewire what I have I thought that if I replace this one with whats supposed to be in there it might be easier than trying to rewire everything with a totally new amp.
post #10 of 10 (permalink) Old 06-11-2019, 09:27 PM
oji
Yea, if he have another amp to use than thatís definitely an easy way to isolate the issue. Iím interested in hearing what your results are.
oji is offline
  Second Generation Nissan Xterra Forums (2005+) > The Marketplace > Wanted Items
