Airmapper's Rear Cargo Area Project - Page 5 - Second Generation Nissan Xterra Forums (2005+)
 43Likes
post #41 of 49 (permalink) Old 05-03-2018, 02:14 AM
2011 Night Armor ❌terra Pro-4X [New Hotness]
Ripper's Avatar
Man, everyone is using those ammo crates now!
Ripper is offline
post #42 of 49 (permalink) Old 05-03-2018, 09:06 AM
That turned out really nice - great job!
I really like how you can still use the cargo area underneath.
Airmapper likes this.
post #43 of 49 (permalink) Old 05-03-2018, 05:06 PM
Originally Posted by Airmapper View Post
The elevated cargo rack. I have it held with 4 bolts. I think what I see as flimsiness is the fact I don't have the top welded in which should add lateral stability, and I didn't have all 4 mounting bolts secured. I used angle iron top and bottom to try and gain some strength without having to weld in gussets
Well my bet would be the gussets are probably worth the extra hassle. Turned out well though, good job! I am eyeing a rear rack more and more as the X-Trail (my other vehicle) has about the same amount of cargo room in the rear so having the rack in the Xterra won't be as much of a hassle anymore.
post #44 of 49 (permalink) Old 05-03-2018, 05:24 PM Thread Starter
Airmapper's Avatar
I would have leaned in that direction also, but actually it turned out very rigid with just angle iron. It's extremely solid, more than I would have guessed. I drove the X today to shake it out and no annoying rattles. Some washboard in my drive made something rattle but it was feint and I'm pretty sure it was there before.
I think it's pretty overkill as is, I welded the 2 halves together, and welded on the rail covers, so it's not bolted together as intended when it was a hitch rack. The rack is welded down to the leg assemblies on top the flat of the 2" angle. The angle iron is reinforced from flexing by the legs as they are welded on the inside of the bend. The legs sit on large angle pads that bolt flush to the top of the slide mounts.
Really for safety concerns in an accident I'm planning to avoid anything heavy in the rack anyway.
Of all of it my greatest concern for a failure point is where the floor track channels mount to the floor. I used higher grade bolts but they are still of smaller diameter than I would have liked.
2011 Nissan Xterra PRO-4X - 6 MT
Check out my:
Airmapper is offline
post #45 of 49 (permalink) Old 05-03-2018, 07:21 PM
I must have misread, I read it as though even after the angle iron it was flimsy or whatever. We used angle iron rods to reinforce a 95 pathfinder floor that needed everything cut out. Por15'd the whole thing and it is solid.
post #46 of 49 (permalink) Old 05-04-2018, 09:55 PM
2006 Midnight Blue Xterra SE
dmski's Avatar
Wow that came out great! Really like that slide out setup.
2006 Nissan Xterra:
dmski is offline
post #47 of 49 (permalink) Old 09-23-2018, 11:10 PM Thread Starter
Airmapper's Avatar
I guess I never updated this after some use.
Now I've put some trips on it, I love it, best mod I've ever done. The amount of gear organization is wonderful. The under floor bin is stocked with tools and gear and I can reach it with minor effort.
Here it is not too long after being finished in use with the lights on at night.
Not long after that I figured out a Trail Kitchens King Charles chuck box would fit perfect in there, now I'm rolling with the chuck box and fridge setup, no crates to screw with aside from one I put food in and set on the upper shelf. Now I have a cooking surface and place to set items I'm getting out of the box after I modified it to hold the door flat with a cable and hook.
Check out my:
post #48 of 49 (permalink) Old 04-30-2019, 10:53 PM
2013 Night Armor Xterra S
Taylor Spaulding's Avatar
Just found this project, and that is the coolest setup ever. Have you ever thought about selling premade kits for those of us with less fabricating skills? (Mostly the welded/cut pieces)
Taylor Spaulding is online now
post #49 of 49 (permalink) Old 05-01-2019, 09:46 PM Thread Starter
Airmapper's Avatar
Thanks. I'm reluctant to offer any kits as I've seen too many home shop X vendors get overwhelmed and let folks down. I never want to get busy with life and do that. If I was set up better for it, maybe.
Sent from my SM-G930U using Tapatalk
Check out my:
