Ham Radio - Page 93 - Second Generation Nissan Xterra Forums (2005+)
 194Likes
post #921 of 924 (permalink) Old 03-14-2019, 01:14 PM
2007 Avalanche White Xterra SE, 4x4
Chug's Avatar
^^^ Head unit, is mounted at the vents. Might be too much heat or cold Blowing on the unit. Unless yea seal that off. Just a observation.
Mic spot.. I placed next to shifter, for Ease in Grabbing and less chance leg Hot mic.
Programming port in front on the Radio?. Or in the back. Buddy installed his unit wrong way, Could not reach the Programming port with cable. Me holding my Rum & Coke laughing. I TOLD YEA!! Data port is needed later. haha
What is that Goo on the Antenna mount?.
Good install. head unit has nice clear display.
Never give up the high Ground!!
" A man who wouldn't cheat for a poke don't want one bad enough. "
Gus McCrae-
Chug is offline
post #922 of 924 (permalink) Old 03-14-2019, 02:19 PM
2015 ❌terra
Bumbler's Avatar
fuses
yes, there are inline fuses about 12 inches back from battery attachment. Excess line is coiled up beside the battery.
Fuse holder is plastic and one is visible in the photo. 15A amp fuses, if I recall correctly.
TerryD likes this.
Bumbler is offline
post #923 of 924 (permalink) Old 03-14-2019, 02:23 PM
2015 ❌terra
Bumbler's Avatar
Originally Posted by Chug View Post
^^^What is that Goo on the Antenna mount?.
If Goo refers to the grey area, that is a metal component of the antenna mount. Not sure why the photo does not orient properly.
Bumbler is offline
post #924 of 924 (permalink) Old Today, 08:30 PM
2012 Super Black XTERRA S
Armyx's Avatar
KG5ZEV here. Here is my set up. I first started with an Icom 5100a on a ram mount attached to the dash above the radio. But in Oklahoma heat it was getting warm. So not it it’s mounted on a ram mount Uber the radio. I have a blue sea fuse block under the back seat driver side that runs the actual unit mounted under the driver seat.
File Type: jpeg F4437864-C68D-4A4F-9161-BAA8AEB75CC9_1552782574175.jpeg (285.1 KB, 1 views)
Lead, Follow, Or get out of my way!
Armyx is online now
  Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Electronics
