Toyota OEM Bottle Jack - Anyone else have One? - Second Generation Nissan Xterra Forums (2005+)
 5Likes
post #1 of 13 (permalink) Old 05-16-2019, 01:13 PM Thread Starter
A while back I found a decent deal on a never used mechanical OEM Toyota bottle jack. I don't have a photo of it, but it's this one:
https://www.toyotapartsdeal.com/oem/...111-0c010.html
The simplicity of it, the extension, and the ability to carry it in any direction without risk of leakage, versus the hydraulic bottle jack I had been carrying, were what appealed to me.
It came with a rod with a hook on the end to raise and lower it, but I am trying to figure out a good bolt on solution to use the stock Nissan hardware with the Toyota bottle jack. Here's the Toyota jack, the Nissan rod, and the Nissan scissor jack for comparison.
The only idea I've got so far would be a couple of small rounded rectangular plates with holes or slots that I could bolt onto the Toyota jack. Not coming up with any other great ideas so I'm open to suggestions.
Anyone else carry one of these?
Hawk136439 likes this.
outback97 is online now
post #2 of 13 (permalink) Old 05-16-2019, 01:26 PM
Hawk136439's Avatar
You could use a couple pieces of L-steel and do something similar to your plan but the L-steel wouldn't twist when you used the jack. See Below for crude Paint Drawing...
outback97 likes this.
2011 Black PRO-4X <-- Hers
2006 Ford Ranger 4x4 <-- Mine
Hawk136439 is online now
post #3 of 13 (permalink) Old 05-16-2019, 01:35 PM Thread Starter
Nice! Or maybe even a rectangular tube (or pipe?) with a hole and a slot for the Nissan end that would slip over the Toyota end and attach with a bolt through it?
post #4 of 13 (permalink) Old 05-16-2019, 01:59 PM
Airmapper's Avatar
Actually, I do. It's in my Toyota.
Are the extensions similar or do you not have the Toyota OEM hook end at all? I think both have a square end to end extension, but if it's the same size square I'm not sure, never tried to mix my T4R and X stuff like that. If it is, you could simply just plug the hook type jack turning end into the Xterra rod...
Edit.....apparently I can't read today, basically what @outback97 said only I'm suggestion the OEM stuff from both ends might even work together. I'm not in a position to check mine out right now or I'd go look.
2011 Nissan Xterra PRO-4X - 6 MT
Check out my:
Airmapper is online now
post #5 of 13 (permalink) Old 05-16-2019, 02:04 PM
Hawk136439's Avatar
I'm curious does the yota jack offer more extension than the Nissan one?
post #6 of 13 (permalink) Old 05-16-2019, 03:05 PM Thread Starter
My Toyota bottle jack came with one "L" shaped metal rod with hook end and offset handle. It's similar to that used on some scissor jacks, at least it's a lot like the one on my Subaru. The higher capacity Toyota bottle jacks (Land Cruiser and probably some other models, maybe your 4Runner) come with a multi piece handle that connects with 3/8" square drive extensions, I believe.
Either way, the terminal end of the Nissan handle is the "T" shaped one, so I'm hoping to come up with something to adapt it to my Toyota jack, or even a higher capacity one if I find a replacement down the road.
That's a good question. I have not compared them, but I can tell you it's definitely got more range than my 6 ton hydraulic jack. I want to say it is around 20" when fully extended, while also being lower profile in storage.
Not sure if this image will work since it's hosted on a Toyota forum, but this gives you an idea of the extension.
post #7 of 13 (permalink) Old 05-17-2019, 12:41 PM Thread Starter
I compared the two last night to see what the extension difference is.
The Nissan scissor jack of course has a lower profile when not extended. About 3 3/4" versus 8 1/4" for the Toyota bottle jack. When extended, the scissor jack is about 15 3/4" and the bottle jack is 19 3/4".
If I figure out a workable adapter I'll be sure to update the thread.
post #8 of 13 (permalink) Old 05-17-2019, 10:14 PM
Ford used to use something very similar in their F150's, maybe still do? I had a couple. The problem was that they were built like crap, and after half a dozen uses they quite working - the usual failure mode being the second "step" in the jack would stop working, meaning they would no longer go high enough.
Possibly the Toyota one is much better, but I honestly wouldn't put much faith in any OEM jack. There pure costs for the OEM. No one pays attention to the jack quality, or uses it to decide on what vehicle to buy - so they go lowest possible cost to build as most people never use them or use them once or twice in the life of the vehicle.
post #9 of 13 (permalink) Old 05-20-2019, 01:01 PM Thread Starter
Good point about OEM. I don't know how the quality of the Toyota jack compares to aftermarket bottle jacks, but I'm going by what I've read, and it seems like a decent number of people on expo and ih8mud like them.
This thread on expo
https://expeditionportal.com/forum/t...ements.162040/
led me to find these on amazon
https://www.amazon.com/s?k=scissor+jack+adapter
and that might be an answer to how I could adapt the Nissan rod to the Toyota jack.
post #10 of 13 (permalink) Old 05-21-2019, 04:57 PM
2006 Storm Gray Frontier OR KC NISMO 4x4 6MT
mrpulldown's Avatar
Use those with care. They are close to maxed out by just lifting one corner of a Tacoma. I have busted 2 using while recovering stuck vehicles. One on the Tacoma that it was for. Another on a jeep Cherokee.
mrpulldown is offline
FS: Titan OEM and Aftermarket Suspension Bits c_morse For Sale 4 05-23-2014 10:08 PM
How-to: Add a Bottle Opener to the Spare Tire Carrier tighthams How-to's 12 11-01-2011 11:22 PM
SOLD: Brand New Toyota OEM foglight switches 3/$20 shipped Surf and Snow For Sale 10 06-30-2010 04:50 PM
Toyota OEM fog light switch. $8 + shipping dark_knight For Sale 1 07-09-2009 09:46 PM
SOLD: 5lb Powertank bottle (blue) and bracket OregonX For Sale 0 07-19-2007 02:15 PM
