On Board HOT Water - Page 3 - Second Generation Nissan Xterra Forums (2005+)
post #21 of 24 (permalink) Old 05-23-2019, 11:34 AM Thread Starter
2013 Night Armor Xterra S
Taylor Spaulding's Avatar
Originally Posted by Longboardr View Post
Other than aesthetics I don't see a problem.
Doesn't this suggest not only a leak, but corrosion of the fitting which will lead to more leaking or failure?
Taylor Spaulding is offline
post #22 of 24 (permalink) Old 05-23-2019, 11:43 AM
Looking again I think you're right about the leak. I thought it was corrosion on the brass from an external source originally, but the hex looks clear of corrosion. If the clamp can't be tightened any more than it is I'd replace it with a beefier clamp, clean off the (coolant residue?) and keep an eye on it.
post #23 of 24 (permalink) Old 05-23-2019, 01:58 PM Thread Starter
I'm fairly positive that the coolant is corroding the brass fitting. I'm incredibly worried that the copper brazing in the stainless steel will corrode away completely which would mean coolant in my water. Additionally, it could mean that I end up with a catastrophic failure of the fitting.
The correct thing to do is at LEAST switch out the fittings. But I'm also wondering if flushing the coolant might help to reduce the corrosion in the heat exchanger. There SHOULD be corrosion inhibitors in the coolant, but it doesn't seem like it's inhibiting too much.
post #24 of 24 (permalink) Old 05-23-2019, 02:43 PM
2010 Midnight Armor ❌terra X
MeHere!'s Avatar
From the little I've read coolant does corrode brass faster than aluminum (aluminum said in a brit accent, cuz I love it)
MeHere! is offline
Xterra Onboard Water System Thievingpoodle Xterra Projects 21 01-18-2017 01:46 PM
Water Crossing Preparation Guidelines ChrisHaynesUSA Powertrain & Driveline 5 01-14-2016 07:05 PM
Water in my intake, possible xterraboat jr... Suckafish Powertrain & Driveline 21 09-28-2011 06:03 PM
Dropped the black berry in water, works again, keep it or keep replacement? Mark Off Topic 26 07-05-2010 02:31 PM
redline water wetter xterramex General Xterra 18 04-21-2010 03:14 AM
