HF Alum Bumper Winch Install Planning - Page 2 - Second Generation Nissan Xterra Forums (2005+)
 6Likes
post #11 of 17 (permalink) Old 03-11-2019, 05:16 PM
2012 Lava Red Xterra Pro-4X
nwcoffeeguy's Avatar
I have nearly the same setup your installing. I too clocked the handle to the front but you may consider putting a small block/spacer between the baseplate of the winch and the inside front of the bumper. Reason being is if the winch shifts forward at all you will not be able to rotate the handle - ask me how I know...
nwcoffeeguy is offline
post #12 of 17 (permalink) Old 03-11-2019, 06:13 PM
2015 Glacier White ❌terra Pro-4X
Haha,....that's exactly why I clocked mine towards the radiator instead.
nwcoffeeguy likes this.
prodragon4x is offline
post #13 of 17 (permalink) Old 03-11-2019, 06:41 PM
Senior Member - AKA Jyoung992
2015 Glacier White Xterra Pro-4X
Dyno992's Avatar
This will be useful in a few weeks. Thanks for posting.
Dyno992 is offline
post #14 of 17 (permalink) Old 03-11-2019, 07:22 PM Thread Starter
2014 Brilliant Silver ❌terra S
Kilo Sierra's Avatar
Heh. I was looking at your picture in another thread and comparing it to an amazon picture of your winch to see if I could figure out which way you clocked it.
I'll be definitely keep that in mind.
Zombie Hunter: 2014 Silver Xterra S -
"I am not afraid of an army of lions led by a sheep; I am afraid of an army of sheep led by a lion." -Alexander the Great
Overland Bound #13805; Tread Lightly! Member
Kilo Sierra is offline
post #15 of 17 (permalink) Old 03-11-2019, 07:57 PM
2013 Cayenne Red Xterra S
Apples491's Avatar
Originally Posted by Longboardr View Post
The Hall Effect sensor is part of the X. It's how the X sees an electrical draw on the battery. Our alternator doesn't always charge in an effort to save fuel. If you follow the negative battery cable from the battery to the other end you're at the Hall Effect sensor. If you wire anything between the battery and the sensor the X won't recognize it as a draw on the battery.
I know zip, zero, zilch about wiring a winch to the X, just trying to make you aware of the Hall Effect sensor and what it does.
That's interesting and I'll have to take a look and keep it in mind as I wire in the future. As it stands on my truck right now, every accessory I've wired bypasses that sensor. I picked up a battery terminal spliter. The stock negative wire goes into one of the slots. The rest of my accessories (Blue sea fuse block, stereo amp, winch, lights) take up the other slots. That's how I've seen most wiring installs.
Where would you tie these in to take advantage of the sensor?
Apples491 is offline
post #16 of 17 (permalink) Old 03-11-2019, 09:02 PM
To avoid any noise in the ham radio I installed I ran a ground to the fuse block I added. I attached my ground to the screw that holds the wire coming off the Hall Effect sensor that attaches to its mounting bracket. I have absolutely no idea how many amps can be pulled through the sensor, it's not something I worried about with my relatively low 100 amp max draw wiring. I mean, it's not like you're running the starter and the winch at the same time, but I'd want to know how other people wired their winch...
Apples491 likes this.
post #17 of 17 (permalink) Old 03-11-2019, 10:18 PM
Snagger's Avatar
I don't know how many amps can be pulled through the sensor or other wiring either, and this is where it would go if grounded to the frame or other ground. This would be the reason I would follow the manufacturers instruction and ground it to the battery. A winch can draw over 400 amps. I have mine grounded to the battery, no problems. I don't use the winch a lot but when I do I am conscious of the strain on the battery, so I just take it easy and slow. I also installed a decent battery.
Winch controls in the dash are the way to go. No controller to connect, always ready to go.
Snagger is offline
How-to: ShrockWorks Front Bumper Install - PBR usmc xterra How-to's 129 02-09-2019 01:43 PM
Review: Black Widow Gear Rear Bumper w/Tire Carrier 14xterrapro4x Product Reviews 107 12-08-2017 06:43 PM
SOLD: Calmini Front Plate Bumper with Radiator Skid JFanaselle For Sale 12 03-20-2017 10:49 PM
Review: 2009+ RockyMtnX Front Winch Bumper tomrejzek Product Reviews 8 12-04-2014 11:59 PM
Warn winch install into Shrockworks Front Bumper dpatton ShrockWorks 4 12-16-2006 07:03 PM
