How-to: Stop Hood Squeak - PBR - Page 5 - Second Generation Nissan Xterra Forums (2005+)
 5Likes
post #41 of 49 (permalink) Old 12-16-2017, 11:29 AM
Administrator
2006 Silver Lightning ❌terra "S" 4x4
Old Navy's Avatar
All (01) Photos placed into PB's Purgatory, have been Resurrected for this Thread!
brokefoot likes this.
"D'Garv"
Member #272
Stock Silver Lightning AT
Live Free. Drink Good Beer. Eat More Sushi.
Old Navy is offline
post #42 of 49 (permalink) Old 12-16-2017, 07:57 PM
Veteran & LPM
VMBiohazard's Avatar
Mine wasn't the latch, it was the rubber stops not being long enough, so I used felt pads and no more squeak.
VMBiohazard is offline
post #43 of 49 (permalink) Old 12-17-2017, 01:15 PM
2012 Night Armor Xterra Pro-4X
Jkm101197's Avatar
I tried adjusting the latch on my 2005 X it still squeaked. I used electrical tape like some have suggested in earlier posts. Ive though of Plasti-dip or rubber bed liner as another aturnative.
Jkm101197 is offline
post #44 of 49 (permalink) Old 12-25-2017, 07:25 PM
2015 Metallic Blue Xterra X
BostonX's Avatar
Ok, noob question. People have mentioned using electrical tape or duct tape. What are you taping down?
BostonX is offline
post #45 of 49 (permalink) Old 12-25-2017, 08:39 PM
2005 Silver Lightning Xterra SE
Ezdaar's Avatar
I tapped a inflated punching balloon on top of radiator support, alil harder to close the hood but it works.
Ezdaar is offline
post #46 of 49 (permalink) Old 12-26-2017, 12:16 AM
Jkm101197's Avatar
On the hood the U shaped part that goes in the latch in front of the radiator. If you put electrical tape around the bottom of the U shaped part it should fix the squeaking. Look at the U shaped part you will see where it is wearing (paint will be rubbed away down to bare metal) this is how mine was.
post #47 of 49 (permalink) Old 01-22-2018, 10:46 PM
2006 Red Braun ❌terra, 2007 Red Titan & 2013 Red Altima
Montag's Avatar
Originally Posted by CThoreal View Post
Put adhesive felt furniture pads under the three forward hood bumps and adjusted bumps accordingly, about 4 months ago. Been squeak free ever since regardless of how dirty they get.
I put rubber 3M Tape in the same places and it has worked for 2 1/2 years! Man it was annoying.. I tightened the hood latch, greased every friggin thing. Thank God and Greyhound it's gone!
CThoreal likes this.
Montag is offline
post #48 of 49 (permalink) Old 02-05-2019, 05:12 PM
2007 Lightning Silver Xterra S 4x4 "BaseCamp" Edition
silverflash's Avatar
man o man. so i have had the squeak since 2009 or so. my kids back then always said "dad, your xterra sounds like an old army jeep". i put the felt pads under the 3 stoppers and it kinda helped for a while but then came back after a couple years and i have lived with it as "character" since about 2012 or so. Well, i decided that i was bored enough this past weekend as i was stuck home for work and i adjusted the stops. that made it worse and the hood was moving a little going down the road. So I then looked up the fix which the OP nailed.
i found a wrench, loosened all 3 of the bolts indicated, pushed down as far as could and re-tightened. went for a test drive and no squeaks! Hood doesn't move any more! i did order 3 new stoppers before doing the latch adjustment and will install them anyways- not that i have to, but i think it will keep it squeak free much longer.
kudos to the OP!
OEM fog lights, Nissan Bug Deflector, Nissan Seat covers, Trident white a/c unit mod
Rear Timbrens, Flexible mudflaps, GY DuraTrac 265/75R16 C-rated, bil 5100 shocks front/rear, K&N 57-6014 FIPK, Flowmaster 40/custom y-pipe, vistapro radiator, bully dog GT
silverflash is offline
post #49 of 49 (permalink) Old 06-10-2019, 07:24 PM
P4ND4's Avatar
Talking Thank you, it worked!!!
Originally Posted by SteadyHigh View Post
Lots of people have this problem. This is a fix that worked for me.
1. Pop your Hood
2. Grab a #12 Ratchet or Wrench
3. Loosen these 3 bolts
4. Push Locking Mechanism down and the retighen
5. Shut Hood and go for drive, no more noise
P4ND4 is offline
