How To: Tap a Heat Exchanger to coolant hoses - Second Generation Nissan Xterra Forums (2005+)
 5Likes
  • 2 Post By Nasarno
  • 1 Post By Adam12SD
  • 1 Post By Longboardr
  • 1 Post By satown210
post #1 of 5 (permalink) Old 02-28-2019, 02:10 PM Thread Starter
2008 Desert Stone Xterra SE 4x4
Nasarno's Avatar
I'm planning to add Hot Shower capability to my overland build. For that, I found a small heat exchanger to be the least space consuming option. It can be mounted in engine bay using a custom made bracket. But first I need to know which hose I can reliably tap it to.
The hose shall be always carrying hot coolant fluid. I'm not sue if that is true about the heater pipe assembly.
If you have technical knowledge about it, I appreciate your comment and help.
Charles_Alarie and Adam12SD like this.
Nasarno is offline
post #2 of 5 (permalink) Old 02-28-2019, 02:12 PM
Adam12SD's Avatar
Subbed. Sounds like an awesome idea! Curious to see it in action.
Nasarno likes this.
Adam12SD is offline
post #3 of 5 (permalink) Old 02-28-2019, 02:22 PM
I'd think tapping into the line to or from the heater core would be a safe bet.
Nasarno likes this.
Longboardr is online now
post #4 of 5 (permalink) Old 02-28-2019, 02:28 PM
satown210's Avatar
My understanding is that we do not have heater control valves, so coolant is circulating the heater core regardless of the temperature setting on the a/c control panel.
Nasarno likes this.
satown210 is offline
post #5 of 5 (permalink) Old 02-28-2019, 03:23 PM Thread Starter
Nasarno's Avatar
Thanks! I thought so, but needed others' confirmation to ensure.
Now I have to think about the bracket design. It shall be somewhat easy accessible, because water hoses are going to be easy-connect fittings. Coolant hoses are permanently connected, but water hoses (inlet to heat exchanger and outlet to shower) will be connected and disconnected per use.
Some sample images of the quick connect fittings for the water hose:
Nasarno is offline
How-to: Correct and More Problems if Heater Blows Cold at Idle or No Heat jeff_redx Powertrain & Driveline 35 02-10-2019 01:42 PM
Silicone Coolant Hoses, VQ40 Body Lift Length Offroad Gorilla OffroadGorilla.com 0 12-16-2017 11:42 AM
Thoughts and Observations on Engine and Auto Trans Cooling jeff_redx Powertrain & Driveline 53 05-19-2017 07:08 PM
