How-to: Change Oil Cooler Hose (Coolant Return to Engine) - Page 2 - Second Generation Nissan Xterra Forums (2005+)
 6Likes
post #11 of 18 (permalink) Old 03-06-2019, 02:26 PM
1/3Titan's Avatar
"I think the crescent brand are about 13", I remember the length being just about perfect for the job."
I was speaking to adding another tool to the mix as the hose pliers I saw are rounded such that they might grip the hose a little better, but your probably right about them not being long enough to reach down in there.
1/3Titan is offline
post #12 of 18 (permalink) Old 03-06-2019, 03:49 PM Thread Starter
The main issue I ran into was there isn't enough space to open the jaws on regular pliers, if the set you saw has the double jointed design it could work.
post #13 of 18 (permalink) Old 03-06-2019, 10:12 PM
1/3Titan's Avatar
"The main issue I ran into was there isn't enough space to open the jaws on regular pliers, if the set you saw has the double jointed design it could work."
But your not kidding when talking about limited space. It was a challenge but I got it done. One thing that worked for me for getting the bottom hose clamp off was with the 45 degree pliers, going in upside down I was able to pinch the clamp and turn it a quarter turn while pushing down and out of the way.
1/3Titan is offline
post #14 of 18 (permalink) Old 03-06-2019, 10:54 PM Thread Starter
Ha yeah you can tell the factory installed that hose way before they assembled the top of the engine. But nice work man glad to hear you got it replaced with no problems.
post #15 of 18 (permalink) Old 03-10-2019, 07:12 PM
1/3Titan's Avatar
"Ha yeah you can tell the factory installed that hose way before they assembled the top of the engine. But nice work man glad to hear you got it replaced with no problems."
Yep, That hose probably went on before the intake or the Timing Cover. Thanks again for the post. I would have never thought it was possible without tearing the engine apart and those double jointed pliers are new to me. But now their a pair of my favorite tools. : )
1/3Titan is offline
post #16 of 18 (permalink) Old 03-28-2019, 03:56 PM
2013 Xterra 4x4
Stupid question: Do I need to do this to my 2013 X?
applexterra is offline
post #17 of 18 (permalink) Old 03-28-2019, 08:06 PM
You shouldn't. 10 years, give or take a couple years, is the generally accepted life expectancy of rubber stuff on vehicles.
post #18 of 18 (permalink) Old 03-28-2019, 10:25 PM Thread Starter
I don't think you need to worry about it yet, the Nissan hoses are a pretty good quality and should be fine until the 9 or 10 year mark.
How-to: Correct and More Problems if Heater Blows Cold at Idle or No Heat jeff_redx Powertrain & Driveline 35 02-10-2019 01:42 PM
2008 Xterra SE (Engine Oil Consumption and few other Issues) ianX Powertrain & Driveline 6 09-21-2017 08:57 AM
How-to: Change Front & Rear Diff Lube Oil - PBR usmc xterra How-to's 284 08-14-2017 02:21 AM
radiator change /trans cooler inspection dburnash Powertrain & Driveline 6 03-12-2011 07:40 AM
Glossary usmc xterra Brakes, Tires and Wheels 16 08-27-2010 02:10 AM
