How-to: Service/Clean Rear Driveshaft CV Joint - Second Generation Nissan Xterra Forums (2005+)
post #1 of 15 (permalink) Old 02-13-2017, 09:29 PM Thread Starter
2007 Lightning Silver Xterra OR 6MT
I dont now if that are posted before. But nissan says that is not servicing from oem parts. I sure that parts are not listed like Audi and other cars. On my last summer car audi a6 2000. I clean it to like that 4years and still ride fine.For all i take that servicing from Jeep JK rear cv shaft. Pretty same as nissan but its impossible to separe the boot.
http://www.jkowners.com/forum#/topics/61254?page=1
If you take your time i put 1.5hour to removal to reinstall driveshaft.
Simply cut the oem clip and replace by the small one cv clip available anywhere. Put WD40 or other under the boot to make it more easy to slip on shaft.
tskm2 is offline
post #2 of 15 (permalink) Old 02-13-2017, 09:34 PM Thread Starter
tskm2 is offline
post #3 of 15 (permalink) Old 02-13-2017, 09:38 PM Thread Starter
Second set
tskm2 is offline
post #4 of 15 (permalink) Old 02-13-2017, 09:40 PM Thread Starter
Reinstall just before grease packing and put cover back on!!.
That make a HUGE improvement on my x with 196000km/120k mile. With add of new front ujoint no more driveline vibration
tskm2 is offline
post #5 of 15 (permalink) Old 06-21-2017, 08:28 PM
2006 Super Black Xterra 4wd swapped
RoadKiller2006's Avatar
My CV boot has a small cut in it, do you know if there are replacement boots for these? or do i need to buy the dorman 932002 kit to replace the entire cv ?
Also, what kind of grease did you use?
RoadKiller2006 is offline
post #6 of 15 (permalink) Old 12-20-2017, 04:57 PM
2007 Night Armor Xterra SE
Maverick's Avatar
Iím having issues getting the cover on.
Maverick is offline
post #7 of 15 (permalink) Old 01-01-2018, 01:39 PM Thread Starter
i use normal cv joint grease. the cover is really thin i just put silicon gasket around and tap ligthly. (because i broke the small oring).
but now seen rockauto are listed for replacement cv joint.
tskm2 is offline
post #8 of 15 (permalink) Old 01-07-2018, 04:57 AM
Maverick's Avatar
Actually I figured this one out, without having to use any gasket sealer.
The best way to put this plate on without damaging it (it's a pain in the butt to put on unless you do it this way) is take your old CV joint, remove the bearings and carrier stuff and all that jazz, flip it around and use it as a press to press the plate on.
Just do it gently and go around in the star pattern and go around evenly tightening everything down and make sure the rubber seal stays in place as well- It should all clamp down and be nice and flush when you are done.
Longboardr likes this.
Maverick is offline
post #9 of 15 (permalink) Old 01-07-2018, 12:45 PM
ChrisHaynesUSA's Avatar
did I miss the part where part numbers were specified for this GREAT thread?
ChrisHaynesUSA is offline
post #10 of 15 (permalink) Old 01-07-2018, 01:21 PM
Post #5 has the full dorman kit. I believe there's another thread with more discussion about part numbers, different brands, good places to buy from, etc. This thread looks more to me about cleaning and repacking your existing CV though.
