Titan Front Sway Bar - Second Generation Nissan Xterra Forums (2005+)
post #1 of 20 (permalink) Old 08-29-2012, 11:29 AM Thread Starter
2006 Solar Yellow Xterra S 2WD
Whattha's Avatar
Hello all,
I am not finding the an answer so I am now asking everyone. Has anyone used the Titan front sway bar on their X after doing the Titan swap? I am wanting to put the sway bar back on but I am trying to find out what they best plan of action is. Any help is greatly appreciated and thank you in advance.
Whattha is offline
post #2 of 20 (permalink) Old 08-29-2012, 11:51 AM
2007 Night Armor Xterra S
Killswitch's Avatar
Yes, I believe it was ymbhonk that did it. You'd need either titan rims or something equivalent for the end links to fit or I think he actually got PRG's end links to work in the Xterra rim
Killswitch is offline
post #3 of 20 (permalink) Old 08-29-2012, 11:55 AM Thread Starter
Whattha's Avatar
I will be buying 17" wheels to put on once I get the swap done. I am only waiting on a few parts that are on order.
Is the Titan sway bar the same diameter as the Xterra one? Will I need to buy new bushing for the sway bar?
Whattha is offline
post #4 of 20 (permalink) Old 08-29-2012, 01:10 PM
Killswitch's Avatar
Those are questions for someone that has actually done this. There is a reason that no one runs the titan sway bar after the titan swap. That reason is that the sway bar completely defeats the purpose of the titan swap in that it severly limits your wheel travel. If you are running adapters and titan wheels though then you should be all set, as far as bolting it on, I believe everything is the exact same other than it being 6" longer but like I said, try and track down ymbhonk's build thread or PM him and see what he knows about it.
post #5 of 20 (permalink) Old 08-30-2012, 10:04 AM Thread Starter
Whattha's Avatar
Killswitch, Thanks for the info. I looked into ymbhonk and found his build page. Looks great and I sent him a pm with my questions.
I know that the reason people do the TS is to get more travel for off roading and such. My X does not see off road nearly as much as I would like it to. I am wanting to keep the sway bar to keep the body roll to a minimum. Since the Xterra is the vehicle that we take on all our road trips, I am doing the swap to give it a larger stance on the road and also keeping the stability.
Whattha is offline
post #6 of 20 (permalink) Old 08-30-2012, 10:18 AM
2005 Night Armor Xterra Off-Road
Hey nothing wrong with that if your going to be mainly on road. Im going to be adding one on too and remove it when wheeling.
Sent from my DROIDX
1NonlyX is offline
post #7 of 20 (permalink) Old 08-30-2012, 11:07 AM
Killswitch's Avatar
There is nothing wrong with titan swapping and then keeping a sway bar, if I could just toss an opinion/advice out there....If you would like to save a little cash you can always throw some wheel spacers on and give it the wider stance/meaner look without spending a couple grand.
post #8 of 20 (permalink) Old 08-30-2012, 03:15 PM Thread Starter
Whattha's Avatar
Yeah I have done the wheel spacer thing before and it gave me a bunch of bump-steer and i did enjoy it. I have read nothing but great things about the Titan swap and I figured it is the best way to widen the front and still have "factory" steering. I will be using spacers on the rear to help match the stance. I am not planning on getting rid of the X any time soon so why not just nut up and do it right.
Whattha is offline
post #9 of 20 (permalink) Old 08-30-2012, 07:55 PM
2010 Xterra OR 6MT
Did a Titan swap to a Frontier many years ago. Used the Titan steering rack and sway bar. All worked fine. I have had too many rides without a sway bar, I will take the slight compromise for the added streetability.
early 2010 is offline
post #10 of 20 (permalink) Old 08-31-2012, 01:45 PM
2005 Solar Yellow Xterra S
YMBhonk's Avatar
sorry for the late response i just got out of a selection and was in the field for 2 weeks. I never ran a titan sway bar, i did use the PRG end links with the Xterra sway bar for a day until i decided that it was useless.
YMBhonk is offline
