Just finished 3 inch Lift - Extreme Positive Camber - Second Generation Nissan Xterra Forums (2005+)
 7Likes
post #1 of 14 (permalink) Old 05-22-2019, 12:34 AM Thread Starter
So I just dropped my x back down onto the tires today after installing extended radflos 2.0 set in the middle with 1.5 inch top spacers, SPC arms and Moog cam bolts. The rear is an emu leaf pack with 3 degree shim and adjustable prg shackles set in the middle. The results were 37 inch height in front and 36.5 in the rear. Thinking I will put the shackles to the highest setting to even out the rear to the front. The big problem is that the camber looks so positive I can't drive it. I went around the block 1x very slowly and the tires sounded like I was running on flats on the straights and squealing like crazy on the turns. Can anyone tell me where I should have the cam bolts and UPC set to correct this enough so I can get to the tire shop to get a set of 285 75 16 and an alignment? I currently have the SPC set to the +1 "D" setting that the instructions say are default for a 2-3 inch lift and the cam bolts were set with fat part of washer up. You can see the extreme positive camber in the photos. Thanks!
Sent from my SM-N950U using Tapatalk
notoriousptg is offline
post #2 of 14 (permalink) Old 05-22-2019, 12:43 AM
2012 Night Armor Xterra S
Mastermind46's Avatar
I have similar lift with 285/75R16 tires. I have nearly 0 positive camber. My fat part of the cam bolt points more towards the inside of the x. I'm not sure where the SPC ball joints are set though.
Mastermind46 is offline
post #3 of 14 (permalink) Old 05-22-2019, 01:07 AM
Adam12SD's Avatar
If you have spacers AND the radflos set in the middle, how much lift does that give you? If the spacer is 1.5 inches thick it gives you 3 inches of lift (roughly twice the thickness) already... How much does the radflo set give if set to the middle?
I'd imagine you've got too much lift going on. It doesn't look like those cam bolts are going to correct the camber enough to fix your issue.
Adam12SD is online now
post #4 of 14 (permalink) Old 05-22-2019, 01:27 AM Thread Starter
Sorry I should have soecified .75 actual spacer. It's a stacked .5 and .25 spacer set. For 1.5 total lift. I figured putting 3 inch rads in middle would give me 3 inch lift.
Adam12SD likes this.
post #5 of 14 (permalink) Old 05-22-2019, 01:35 AM
Adam12SD's Avatar
Ah okay. Yeah, then I would try and put the cam bolts to their widest point (thicker side of washer towards center of vehicle) and change the SPC setting to E or F.
The directions I see state D gives a +2 degree camber setting. Remember though, that lift pucks will increase positive camber slightly too.
I have the Titan SPCs though, not sure if that's any different. I'm sure someone more experienced could chime in and correct me though.
post #6 of 14 (permalink) Old 05-22-2019, 01:38 AM
Adam12SD's Avatar
Whoops. I read it wrong... I was substituting camber for caster on the directions.
Now I'm all confused too.
post #7 of 14 (permalink) Old 05-22-2019, 01:39 AM Thread Starter
After doing a little digging around here my plan to correct the problem is to set cam bolts to the outside washer in and set the uca close to the bucket as possible. I'm glad I trimmed based on possibly needing that setting! Also move uca washer to e setting. After that dial down the rads until it looks like its possible to drive again and as even as I can tell by eyeing it.
post #8 of 14 (permalink) Old 05-22-2019, 01:41 AM Thread Starter
Hey man thanks for the help! This is my first build, I found this site when I was planning putting on awesome ranchos 8 weeks ago.
post #9 of 14 (permalink) Old 05-22-2019, 07:15 AM
Take a pic of how you have your UCA’s set up.
I suspect you have Titan width UCA’s and Xterra width LCA’s.
jsexton is online now
post #10 of 14 (permalink) Old 05-22-2019, 10:01 AM Thread Starter
I'm suspecting maybe I put them in upside down? Here is best pic I have of uca right now. This was before I set the rads to the middle. I bought the uca from buy and sell on this forum was told they were Xterra.
4-5 Inch Lift - Aftermarket UCA Contact?? Jasontamu Suspension & Steering 6 03-13-2016 08:28 AM
Complete Xterra 2 Inch Body Lift 4x4parts 4x4Parts.com 3 10-05-2015 05:41 PM
Lift Gate Leak dpatton Interior 23 08-14-2012 12:34 AM
Positive Camber after 2 in lift kit and alignment? Jordan Suspension & Steering 3 06-18-2012 03:57 AM
05+ Xterra Lift Options B Slater Suspension & Steering 1 12-05-2006 10:21 AM
