Front Sway Bar - Articulation Question ? - Page 4 - Second Generation Nissan Xterra Forums (2005+)
 20Likes
post #31 of 33 (permalink) Old 05-22-2019, 03:04 PM
SledheadX's Avatar
Originally Posted by X4dblduty View Post
Yeah it really depends on the most use, handling DOES change. I just came back from wheeling and FSB-delete first time helped quite a bit on flex and traction, happy with that! But, driving up and down those mtn roads did give more roll, sluggish, you do need to adjust driving style. And Iím already on Radflos 600lb springs. With stock spring at about 450lbs could be dangerous.
But, here was one observation I found. At first I aired up to 32 psi on my KO2s on the way down, steering and handling still sluggish. Then I aired up to 40 psi, recommended for daily drives, big improvement! Those taller sidewalls will make a difference with air pressure alone. Steering was sharper, handling less lean on turn-in. Worth a try.
Iíve got basically the same setup you do. Radflo with 600lb and stock bumper (for now). Iím aired at 34 for dd on cooper disc. AT3ís. Was thinking Iíd keep them a little soft for extra cushion but with no fsb now, Iíll try your 40 and see what happens.
AWW FRELL!!!
SledheadX is offline
post #32 of 33 (permalink) Old 05-22-2019, 03:12 PM
IssacHunter's Avatar
IMO I don't think the front sway should be removed unless someone is running AM coilovers with at least 600lb springs. I first took mine off 2 years ago when I put on my MK84 setup with 650lb springs and haven't ran it since. Your handling will change but the stiffer springs have prevented most body roll for me and I respond to my fire department calls with my rig so I'm going fairly fast with it. I'm now TS'ed with Radflos with 650lb springs and feel even more stable now. I will say though that taking off the front sway was one of my biggest offroad benefit mods behind the rear sway bar.
Nissan Off-Roaders of the SouthEast (N.O.R.S.E.), Virginia Xterra Club (VAXC)
OverlandBound member #16797 "Adventr-X" Adventure is necessary.
IssacHunter is offline
post #33 of 33 (permalink) Old 05-22-2019, 03:35 PM Thread Starter
2006 Granite Xterra Off Road
X4dblduty's Avatar
I will upgrade to 650s once I have my Warn and Hefty alum installed. Thatís a sure thing. Again, like most recommendations here if youíre on stock springs donít do it, too risky.
On that note the RSB doesnít affect much either way, mines been gone for a while now.
Mastermind46 likes this.
X4dblduty is offline
New front Sway Bar Bushings look odd/not fully Compressed Longboardr Suspension & Steering 11 11-12-2018 09:34 AM
Titan Front Sway Bar Whattha Suspension & Steering 19 06-26-2017 08:42 PM
FS: V8 Pathy Front Sway Bar FS (34mm vs 30mm) NmexMAX For Sale 0 03-17-2016 06:32 PM
Front Sway bar Links and bushing replacement. W/PICS ChrisHaynesUSA Brakes, Tires and Wheels 56 06-19-2012 02:16 PM
A GUY WALKS INTO A BAR. . . . Old Navy Off Topic 4 09-21-2007 02:07 PM
