Clunk during Left Turn-CV? - Second Generation Nissan Xterra Forums (2005+)
 5Likes
post #1 of 13 (permalink) Unread 03-14-2019, 01:22 PM Thread Starter
BlazinGuns's Avatar
I’ve got a noticeable clunk coming from the driver side wheel(?) during slow left hand turns. Only one clunk per turn. I assumed it was a failing cv axle, but there is no visible wear, and everything on the cv looks clean. There is a slight play in the axle (out and in) but still feels clipped in place. Can a cv go bad without tears in the boots? I recently drove over some long stretches of washboard road.
BlazinGuns is offline
post #2 of 13 (permalink) Unread 03-14-2019, 01:54 PM
importpower99's Avatar
Hmmm I am experiencing this issue as well, following!
Sent from my SM-G955U using Tapatalk
BlazinGuns likes this.
importpower99 is offline
post #3 of 13 (permalink) Unread 03-14-2019, 01:57 PM
Adam12SD's Avatar
Worth a try, but I had a severe clunk going over bumps while turning and it turned out to be a loose bolt on my sway bar end link. Felt snug when checking by hand, but when I put a wrench to it (holding the inside shaft with another wrench) it was very apparent it was way too loose.
Adam12SD is offline
post #4 of 13 (permalink) Unread 03-14-2019, 02:02 PM
2015 Lava Red Xterra S
duxsterra's Avatar
x2 for sway bar end link, that would be my guess
Adam12SD likes this.
duxsterra is offline
post #5 of 13 (permalink) Unread 03-14-2019, 02:48 PM
2013 Cayenne Red Xterra S
Apples491's Avatar
FWIW, I had these symptoms about a year ago and it turned out to be a bad SPC UCA ball joint.
Apples491 is offline
post #6 of 13 (permalink) Unread 03-15-2019, 11:45 AM Thread Starter
BlazinGuns's Avatar
How’d you diagnose this?
post #7 of 13 (permalink) Unread 03-15-2019, 11:53 AM
How long did yours last before that?
post #8 of 13 (permalink) Unread 03-15-2019, 03:13 PM
Apples491's Avatar
I didn't know what is was until it got bad enough that I could feel how loose it was in my hand. We also could get it to clunk by jumping on a slider to articulate the suspension on that side.
I bought the UCA used but I'd estimate the ball joint had about 10k miles on it. I also abused the hell out of it so that number may be skewed.
post #9 of 13 (permalink) Unread 03-15-2019, 11:26 PM
meanGREENnugget's Avatar
I would check the bottom shock mount bolt. Mine was pretty chewed up and would clunk at full turn.
meanGREENnugget is offline
post #10 of 13 (permalink) Unread 03-17-2019, 07:17 PM
DaveN's Avatar
Look at the CV axle by the shock mount. If there is a line that means you're rubbing and you need different misalignment spacers on the lower shock mount.
Sent from my XT1575 using Tapatalk
DaveN is offline
How-to: CV Boot Replacement (Missing Photos) penski61 How-to's 7 09-12-2018 10:13 PM
Speed Bump Clunk Front Left Wheel curtism Suspension & Steering 11 05-17-2017 10:23 PM
How-to: Air Bag Light Turn Off - Version I usmc xterra How-to's 71 10-04-2016 01:36 PM
High Beam in Turn Signal Mod jpdraven Electrical 4 05-24-2016 06:09 PM
Clunk Sound when I Turn with New Sway Bushings KCL12 Suspension & Steering 7 11-09-2014 01:27 PM
